Question about Garden
Yard machine tiller won't stay started!
The tiller (B&S engine) wouldn't start this year (ran great for 5 yrs or so). Checked for gas feed ...ok. Checked for spark ...ok. Wouldn't start. Put in new plug and relatively fresh gas. It starts, but only last for a few seconds before shutting off. What should I investigate next?
  • tolkien Nov 17, 2008
    Thanks Joe. I'll work on the carb rebuild over the winter
There is a small diaphram on the side of the carb that simply wears out. It's rubber coated mesh and the rubber coating breaks down and it stops pumping fuel into the carb. Sometimes you can run with the choke on partially, but it will burn 10 times the amount of fuel and cause more damage to the engine itself. I think it's about a $10.00 part.
Posted on Dec 08, 2008
    Problem Solver:
  • 8 Answers
I would suggest you have the carbureator rebuilt, ethonal breats down into a gum that cloggs passages in carb need to be very clean to run properly. use stabil (fuel additive) in outdoor equipment gasoline and Sea Foam is also a exelent fuel additive
Posted on Nov 16, 2008
Try checking the oil. Some of these small engines have an oil sensor that will keep it from running if it is low on oil. Sounds crazy but my buddy just went through exactly the same thing.
Posted on Nov 19, 2009
My 5 hp craftsman tiller won't stay running changed gas sprayed carb new plug started it ran ok next day starts won't stay running dies fast like no fuel but can smell gas.
when it dies see if it will restart using a shot of starting spray in the air cleaner if it starts or sputters, sounds as if you have a plugged up carb you will need to dissasemble and soak in white vinegar for a few hours to un clogg (carefull with any gaskets)
if still nothing even with spray then you have a weak/defective coil or dammaged spark plug (start with plug replacement)
Aug 06, 2014 | Garden
Managemylife
Crank engine a few times. If spark plug is dry carb needs dismantling and cleaning. Probably gummed up.
Jul 10, 2014 | Craftsman 4-Cycle Mini Tiller
The tiller quit running as if it ran out of gas. it has compression,spark,gas and wont run on ether.the flywheel key is ok
You want to drain the gasoline every winter, and use fuel stabilizer. Gasoline loses its effectiveness after about 30 days, so using stabilizer will keep it from going bad so quickly. This is particularly important when it comes to tillers, which you might take out in the spring and fall and store the rest of the year (depending on your usage). Stabilizer will also keep your carburetor cleaner and prevent it from gumming up. Tillers Direct has some good supplies for keeping your engine running well.
Apr 11, 2012 | Yard Machines Garden
I have a manis tiller that wii not run rigth. i have put i a carber kit
My mantis tiller ran fine,I put it up for the winter and now it won't start,I checked to see if it was getting gas which it was, could it be the coil? I did check and they say its very rare that the coil goes out.I also check for any type of spark and nothing. Please help!!!! thanks ,Clay
Mar 26, 2011 | Mantis Gas Mini Tillercultivator 2cycle...
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
FG110 Mini-Tiller stalls once it is warmed up. After about 15 minutes of use it when stall and restart but won't run under load. Once this happens it needs to be inactive for about a month before you...
The problem is that the fuel cap does not allow enough air to get into the fuel tank as the fuel is used. A vacuum is created and it stalls the engine. If you look at the cap from the inside you will see two small slots on each side of the black center piece. I took this apart and opened up those slots a little bit with a hack saw blade. This allows enough air to get into the tank to prevent a vacuum and the resulting engine stall.
Apr 06, 2009 | PDP Systems Dethatcher Attachment for...
Tiller won't start.
I recently had the same issue with a tiller that hadn't been started in over 8 years. Turns out that old gas had left a varnish coating in the carburator keeping the gas from feeding. Rebuilt the carburator with new float, needle valves and bowl, new Welsh plug. Fresh gas and two pulls later it went to churning. Took a short time to adjust the two needle valves for idle and full throttle and we went a-tilling.
Apr 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Mar 21, 2009 | Mantis 2-Cycle Tiller
Fg 110 mini tiller by honda
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
Jan 13, 2009 | Honda 25cc 4-cycle Mini Tiller
Garden Logo
1,483 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
