Question about Hitachi 32CX39B 32" TV
Hitachi 32CX39B When my tv was turned on, everything was fine, but when the xbox got turned on, only a horizontal strip showed on the screen. I tried unplugging everything, and there is still only a horizontal strip that shows part of the picture. One of my room mates said that he hit the top of the tv a little bit, and then it went back to normal. But, now it's just a horizontal strip. There's sound on the tv, but when my dvd player is plugged in, the sound is distorted.
  • Anonymous Jan 02, 2008
    I've had this expensive TV for only 5 years with perfect color etc. but turned it on the other day and there was a 1 inch horizontal line, I've turned it off and on for 2 days but still the same results.
    I may take your advice and bang on it next
    Scholar:
  • 68 Answers
The solution by jomaru is what I would suggest, but in addition the fault may be a bad connection in the power supply regulator chip, giving a low voltage, which may also affect the sound quality. This will need looking at by a local service engineer using at least a meter. Inspect the component boards for burnt resistors which sometimes fail. If the copmonent is located and changed but fails again, a service engineer must be called, beware of high voltages.
Posted on Oct 15, 2006
    Sergeant:
  • 337 Answers
The xbox is just a coincidence,the good thing is your friend tap on the set and it reacted going back to normal maybe for only a second but is good,you have a loose conection is the vertical IC,this the circuit in charge of pushing the picture up and down.The vetical IC is normally mounted in a small heatsink and is flat,it should have 10 pins soldered to the board.The board need the be flip over and the pins resoldered. If you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance from a servicer.Let Us know how it goes and if you need more information.
Posted on Oct 13, 2006
  • Omar Urrutia
    Omar Urrutia Oct 13, 2006
    We need to address the picture problem first before the dvd sound.
    Please rate this solution.
My Hitachi tv will not turn on
My Hitachi used to eat Horizontal output transitors. I do not even know if your uinit has that anymore, but if that goes out the unit wont make the B+ voltage needed to power up the unit.
Sep 19, 2017 | Hitachi Televison & Video
Blue strip (Haze) started showing up in middle of screen.
you need to chang screen or buy new tv ,cause that is not fixable its killed pixels.please leave comment,vote,note.thankyou
Sep 13, 2009 | Hitachi 50V720 Television
Screen only shows horizontal line
if line is left to right in middle of screen the problem is in the Vertical deflection circuit---could be either a soldering problem with the vertical output ic or a bad part in that circuit. If this has been helpful please give me a vote.
Aug 08, 2009 | Hitachi 32CX39B 32" TV
Same kinda thing
that would be your graphic card replace it and your xbox will work like new
Jul 13, 2009 | Microsoft Xbox 360 Console
The channels won't store on my hitachi L19HP03U TV
ohh..your memory ic corrupted change it but it need to program use memory ic copier to copy the ic first ok
Jun 05, 2009 | Hitachi 32CX39B 32" TV
Xbox 360 is showing purple lines on tv screen.
Hi...
Pull out the video cable from both ends.
Re-attach and try again
Let me know
Jan 18, 2009 | Microsoft Xbox 360 Console
Xbox 360 Video Problem
Have you adjusted your tv settings at all, rather has anyone screwed aroung with your tv?
Sep 21, 2008 | Microsoft Xbox 360 Console
Hitachi 27
If the sat feed is on channel 3, and the TV is tuned in and still does not get the feed, check the feed wire to be okay. If all is okay, there is a possiblity that the tuner module in the set has failed.
Jerry G.
Apr 29, 2008 | Hitachi 27CX01B 27" TV
Hitachi 32CX39B
We need to know more details,Disconect the xbox and see if you get a full screen or the problem remains?,Please post a new question. Please dont rate this as a solution.
Oct 12, 2006 | Hitachi 32CX39B 32" TV
Hitachi 32CX39B 32" TV Logo
97 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
