Question about Goodman GMS90703BXA Heater
Heater problems Haeters not blowing baught new heater motor and still no joy, Could i need a relay fuse?
  • 905 Answers
There may be a fuse for it that has blown , or there is no power comming from the source to the motor
Posted on Nov 06, 2008
Have a TOYOTA rav4. The heater fuse 50 amp was blown. When I replaced it. The new one blew as well. Wondering if there is a relay issue?
Never heard of a relay problem blowing a fuse. Believe either your heater motor has an internal short, or a short in the wiring to it, like bare hot wire touching metal.
That's a large fuse. Are you sure the heater circuit is the only circuit for that fuse? If it is, makes it easier to find the short. Unplug the heater motor and see if new fuse blows with key on, and heater motor switch on. If fuse don't blow out, probably your heater motor. If fuse blows , could be your resistor pack for the heater or a wire touching metal, it should cause a large spark and a "pop" when it blows fuse.
Oct 14, 2017 | Toyota Cars & Trucks
My heater dont turn on. Not even blowing
Check your heater fuse and/or relay.
Oct 05, 2015 | Cars & Trucks
Thermal fuse failure
If the relay sticks, that will cause overheating and the thermal fuse to blow.
Feb 27, 2017 | Whirlpool Dryers
No power showing for the ground wire for fan blower motor in 2003 Dodge Caravan se
very confused with diagnostics of this motor
if power was going to earth ..the fuse or relay would blow ..blower motor would spin
if it blows the fan fuse or relay something is wrong with the on /off switch for the blower
picture is the 2003 heater system
if no better make up a new earth wire to chassis for the blower motor
Mar 22, 2017 | Cars & Trucks
How come heater fan wont blow
there are a few things that will cause this problem.
1. it could be the heater fan fuse
2. could be the heater fan motor itself
3, a bad switch or relay
check the fuse and then check for voltage at the heater motor itself, if you have voltage at the heater motor,, give the heater motor box a love tap with your hand and see if it starts to turn, if it does not turn or even if it does ( after tapping it ) - it is time to replace the heater motor.
c...
Jan 04, 2011 | 2000 Jeep Grand Cherokee
No air coming out of the vents
It sounds like the heater motor may not be operating. When you switch the heater fan on can you hear the motor running? If not then it may have blown the heater fan fuse, check the fuse's and then try it again. If the fuse is ok then it could be a faulty switch or fan motor.
Apr 02, 2010 | 2004 Chevrolet TrailBlazer
Everytime i turn my heater on heater on works and blows fuse?
fuse blows. unplug heater blower motor turn ignition on, turn heater on, does fuse blow? if not need to replace heater blower motor
Feb 10, 2010 | 1995 GMC Jimmy
How hard will it be to pull a heater from 1991
if you have to change it,you will need the service manual.but before you do change it look for a sensor,relay,or a fuse going to the heater motor.if the heater motor has not been beaten up than i would not change it .it could have gotten wet and blowen the fuse relay or sensor
Jan 16, 2010 | 1991 Honda Civic
I have a 93 chevy astro van and the blower fan keeps blowing fuses. the fan checks out good, can't locate the relay which I think may be bad. as I can unplug fan and still blows fusew.
The relay is not your problem or it would blow wheather or not the heater motor was plugged in or not if it was shorted,you need a new heater motor.
Nov 12, 2009 | 1993 Chevrolet Astro
Heater blower stoped working
When a fuse blows, it shows a problem in that circut, generally a voltage spike, sometimes a poor ground that causes excessive resistance in the wiring, or a short. I don't know of any connection between the fuse you changed and heater, but anything is possible...Check your body ground, dash ground, heater relay and blower motor. (Motor is mounted on the engine side of the firewall on the passenger side. relay is either on the firewall or inside the power distribution center (black box near battery).
Jan 18, 2009 | 1995 Jeep Grand Cherokee
Goodman GMS90703BXA Heater Logo
41 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
