Question about Panasonic NN-H965 Microwave Oven
Panasonic 1100W high power
My microwave stopped working completely on it's own? I went to use it and it wasn't working, tried plugging it into another outlet, still dead! It is a year old. Any ideas what is wrong. Thanks, L
  • Stephen Peter Ross
    Stephen Peter Ross Nov 28, 2007
    I suspect these panasonic inverter ovens have a serious design flaw...and should be avoided. I also suspect the increasing higher wattage (consumer grade) ovens are more likely to fail earlier because of the higher stresses and energy--so mfrs can sell them more often!
    Here's what happened on my 1250W, top-sized, inverter (DC) oven which is properly placed for venting. After cooking a turkey at 50% power for about 2 hours at placed a bowl with butter to be melted in the oven and started using 1-minute and start buttons--heating at 100% power while observing through window to stop manually before boiling/burning. Within a few seconds, smoke started coming out from around the oven's right side (left side viewed from oven front) at or near the vent opening. I turned the oven off immediately. After a few moments, I attempted to restart but the oven "blacked out" and would not start at all. I verified house fuses and outlets okay. Also, I observed that the food was not the source of the smoke. My theory is that the two hour cooking at 1/2 power caused heat build-up in the oven (due to faulty design), and that when full power was applied that was enought to bring wiring (insulation) or other component to the melt/char point and produce the smoke--or burn a vital component or fuse. I deemed this failure to be Panasonic's liability--the oven had only been light to moderately used for about a year (give or take), and I've never had a microwave fail in less that 6 to 15 years during 30 years of oven ownership--yes I realize that the more recent (and lower priced) ovens are meant to fail earlier--but replacing a top-of-line oven every year...that's ridiculous.
    Anyway, I decided to remove the cover and look for damage to see if repair was feasible--and to be able to bring the problem to Panasonic for settlement. Only problem now is, that I am unable to find a driver tool to remove the "anti-tamper," round-head, toryx/hex type screws attaching the oven outer cover. The required screwdriver must be a national secret...since I've searched for hours online for any reference to the tool, its name, or any vendor, only to find nothing. Plenty of advise to remove the outer cover, but nothing on how to remove the cover screws.
  • Anonymous Mar 25, 2014
    Hi I have a Panasonic microwave 1100w stainless steal it just came up with H 98 can you plz tell me what that means thank you
  • Panasonic Master
  • 9,098 Answers
It may have a blown fuse or - assuming yours is a model NN-H965 - a defective inverter. The fuse is generally located on the bottom of the chassis of the microwave. You have to remove the outer cover on a counter top model - or the front panel assembly on an over-the-range model. There are several reasons why it may blow. If the fuse is loose in the holder, the fuse and the holder should both be replaced. If - with the microwave disconnected from the wall - you can easily turn the fuse with your fingers while it's in the holder, then it's too loose. What happens is the loose connection generates too much heat, causing it to melt internally. If so, you'll usually see a ball of solder at a point where the cap meets the body of the fuse. If the fuse blows as soon as you plug the oven in the wall, or when you open the door, the problem is likely with the door switches. You can find my files "doorsw.txt" and "safety'txt" via Google. They give you the safety warnings and cover the diagnosis and replacement of the door switches. If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. They offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number. Be safe!
Posted on Oct 14, 2006
Light went out/I removed panel over the housing where the red fuse [I think it is the fuse]is located. The location is inside and very hard to get at. I can only get a single finger in the hole and then don't know what to do. It seems solid but I can't tell. Please, what do I have to do to get the light to work. /s/John Bridell, as harrybatt @comcast.net
Posted on Mar 08, 2009
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
SOURCE: panasonic 1250 watt microwave approx 5 yr old.
something burned out, has there been a thunderstorm lately?
if you get a new one, plug it into a surge protector.
Posted on Jul 16, 2009
heatman101
  • 43501 Answers
SOURCE: My Panasonic NN-L531WF microwave stopped
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 21, 2010
Panasonic genius 1100w inverter microwave stops after 23secs.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here:
Support Panasonic
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Panasonic Microwave Ovens
Where is nn_sd297 fuse located?
i forget where mine was but it is the first thing the hot side of the power line gets to in the oven. Sometimes in a holder, sometimes wired in.
Jan 25, 2016 | Panasonic 1100w over Range Microwave Ovens...
Samsung microwave malfunction
I too have this problem with my KitchenAid KHHS179LSS-5 model. Based on the owner's manual I located behind the grill which pulled off, the F7 Error code indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
After removing the control display, there is a virtual zoo of connectors. So unless you repair microwaves on a regular basis, it may be difficult to ascertain which ones go to the magnetron thermostat. I will probably resport to shelling out the dough to get someone to fix it. Sorry I couldn't be more helpful.
Jun 27, 2013 | Microwave Ovens
We have a Panasonic Microwave. model number NN-P295 1100W. We had a leak above our microwave 3 days ago. The fan immediately came on and will not shut off. No features will work on the microwave. We...
This not good! from your description the problem is in the keypad controller, on the back of the keypad is a circuit board that contains the microprocessor and additional parts that control vital areas of the microwave oven. The leak has penetrated the vital areas where the electronics are housed, I suggest you replace the microwave oven because the cost will probably more than what a new one will run.
Feb 08, 2011 | Panasonic NN-P295SF Microwave Oven
Hello,i have microwave KHHS179LSS-2. Display indicate code F7. I check magnetron thermostat resistance is 0 ohms. I replace 1100W inventor. Microware stil indicade code F7. Thanks for you help.
From a similar model's tech sheet (and yours should have one hidden inside):
F7
Power to magnetron interrupted
3. Check resistance of the magnetron thermostat.
4. Check the magnetron. See this file for details.
5. Check wiring to the 1100W inverter and control system. See "Checking Inverters"
6. Check operation of all interlock switches. See this text file. Check door, hinge and cavity front alignment. Adjust as needed.
7. If switches operate correctly, replace 1100W inverter.
8. If problem persists, replace electronic control.
9. Plug in microwave oven or reconnect power.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHHS179LSS2 without dashes or spaces) from the tag on the oven here.
Nov 25, 2010 | KitchenAid Microwave Ovens
Panasonic Microwave Genius 1200W stop working. I move a little bit electric cord and it went on again. Then I pressed one min quick reheating. It blinks and stop working. Any solution ?
Assuming that you mean the whole unit goes off as if you unplugged it then the problem sound like the incoming power//you say that if you moce the cable then it comes on untill you try to use it //replace the whole cable from plug into the machine
Dec 29, 2009 | Microwave Ovens
Our microwave went dead. It's only three years old. My husband put some chicken wings in, closed the door, and everything went black. We plugged in a nightlight in the power source and it worked. Any ideas...
a few possible causes,
1, the high voltage fuse,
2, the high voltage capacitor
3, the slow blow fuse ( normally found on a small pcb inside unit)
other than that, check the door switches and maybe the x former.
good luck.
Jul 04, 2009 | Whirlpool GH4155XP Microwave Oven
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
New Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it's still not working, you'll need to contact your nearest Panasonic-authorized servicer.
Aug 24, 2008 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-H965 Microwave Oven Logo
795 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
