Question about Apple iPod nano
Ipod Nano 1G
My ipod seems to be frozen. It turns on, charges, but the wheel does not move. What can I do?
There is a cable inside the IPod itself, that connects the wheel to the internals of the device.
It could have become dislodged or have deteriorated.
I would very highly reccomend not taking it apart and attempting to fix it yourself.
Take it to something like best buy or another electronics dealer and they might be able to fix it for you, since they have the correct tools.
Posted on Nov 06, 2008
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
Ipod Nano 4gb - click wheel inop
HI,
Since you hav tried resting the ipod...Also try restoring the ipod and update the software using Itunes and check it...
Feb 02, 2009 | Apple iPod nano
IPod Nano 3rd Gen...click wheel seems to be frozen....
Hi, First find whether the Hold switch is in off hold position... ( Hold switch can be found at the botton or on the top of ipod) then try:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jan 13, 2009 | Apple iPod nano
IPod click wheel frozen
how do i unlock my ipod
Jun 05, 2008 | Apple iPod nano
Ipod screen frozen
Hold the center and menu buttons together for about 7 seconds. It should work
May 25, 2008 | Apple iPod nano 3rd Generation
Ipod nano
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Apr 01, 2008 | Apple iPod nano
Ipod nano and ipod video 5th generation
First off, simply press the center and menu buttons at the same time to reset the iPod video. That is the common way to fix a frozen iPod.
In regards to the Nano, sounds like the scroll wheel is defective. We would recommend replacing the scroll wheel if a reset does not do the trick.
Rick
EverGreen Electronics
Feb 18, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
32 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
