Question about Toshiba CZ27T31 27" TV
PANASONIC DVD PLAYER CONNECTION TO A TOSHIBA PROJECTION TV
I HAVE A TOSHIBA PROJECTION TV AND I HAVE A RECEIVER CONNECTED BUT I DON'T KNOW WHERE TO CONNECT THE DVD PLAYER IN THE BACK OF THE TV. PLEASE HELP!
  • 905 Answers
S-video input for a better picture , or yellow jack(RCA jack) for video, then red and white for audio
Posted on Nov 06, 2008
  • 1 more comment
  • jason Nov 06, 2008
    for digital sound use the optical input to your reciever to get the digital input signal
    please give a rating for my help , thanks
    and if you need more help just ask and help the best way possible
  • jason Nov 26, 2008
    thank you ! and thanks for using fixya !
    And if you need any other asistance just ask and I'll help
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
We are trying to connect our Sony DVD player to our Toshiba Tv We plug it according to the diagram. We get no sound or picture although the power is on to the DVD player. We have the TV on Channel 3 ....
Make sure the connections are correct according to the Diagram.Sony DVD player Video Out and Audio out should be connected to Toshiba TV ,AV1 or AV 2 Etc. don't forget to switch the TV from TV mode to Video mode (Input mode)
Jun 13, 2011 | Televison & Video
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
No picture
is your TV connected to a receiver or DVD player? I want to know so that I can detect if the fault is from the video cord that connects your TV to the receiver or DVD player.
Or, you can connect a DVD player to the TV and see if there will be any picture.
I hope you understand what I'm trying to say above. Your TV not having picture might be a fault from the display board/ic inside the TV or it might just be a bad wire connecting from the TV to DVD player or receiver.
So try to check the wires at the back of the TV, to be know if its a wire fault or not.
Good luck.
Jun 22, 2010 | Televison & Video
Cant get connected
Your DVD player should have came with a cable with 3 plugs on each side. Plug the matching colors into the jacks on the back of your DVD Player. Then if your TV has the same color jacks, plug the cables into the colored jacks.
Feb 28, 2009 | Toshiba Televison & Video
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Video Connection Issue
Use an HDMI cable! It carries video and sound in high definition which is blu-ray dvd player. Costs about $25.00-40.00.
Dec 30, 2008 | Toshiba 43H70 43" Rear Projection...
I am trying to hook up my tv to my receiver, I have a dvd vcr combo,and cable box
Audio: There should be a set of audio outputs on your TV. Connect those to the AUX inputs of your receiver. When you turn on your receiver, set it to AUX. Set your TV volume to approx 1/3 and adjust the volume on your receiver. There's probably a menu section on the TV to turn off your TV speakers so the sound will only come from your receiver.
DVD/VCR (I'll call it DVD from this point forward): Connect the video (yellow) output from the DVD to the "video input" on the back of the TV. Connect the audio out on the DVD player (red) to the red audio input on the back of the TV, then do the same with the other audio (white). When you want to use your DVD player, you'll select "input 1" as the input on the TV.
Cable: Your cable box probably has numerous output types. I have the cable box hooked up to both the DVD player AND to the TV; one output type going to the DVD player and another output type going to the TV. I like to use the HDMI output from the cable box to the TV, and the composite video from the cable box to the DVD.
Hope this helps. Let me know if you need more info.
Mar 18, 2008 | Televison & Video
How to connect my Logitech X-540 speaker system to my dvd player or tv
On the logitech speakers, connect all the colored cables to their coordinating colors on the back of the subwoofer EXCEPT the green one..you need the special Y connector that came with the speakers. (the red, white and green little one). Connect one end of the green cable to the subwoofer, connect the other end to the Y connector. Now you just need to correct the red and white cables from your tv or dvd player into those red and white cables and MWAH!!
Mar 01, 2008 | Logitech X-540 Computer Speakers
Toshiba CZ27T31 27" TV Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
