Question about Plantronics (6440201) Professional Headset
Plantronics Headset DS 500
My headset has a loose wire on the left speaker, how do I dismantle the headset without causing damage to the headset?
  • 556 Answers
SOURCE: iTunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Posted on Dec 06, 2007
SOURCE: Plantronics 330 Bluetooth headset
I need help installinig my planatonic 330
Posted on Feb 03, 2008
SOURCE: Need the Explorer 220 Plantronicsa headset operating manual
If you click this link it should bring up the user manual! Hope this Helps!
http://www.plantronics.com/media/media_resources/literature/user_guides/Explorer220_NASA_ug.pdf
Posted on Dec 12, 2008
keekus
  • 83 Answers
SOURCE: I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Posted on Jul 18, 2009
sams_trix
  • 93 Answers
SOURCE: Where can I download a driver for my plantronics
LJBENGE try to visit this site http://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Hardware&s=Plantronics%20DSP%20500%20headset and try the drivers for vista... good luck!
Posted on Jan 19, 2010
Testimonial: "I did that before contacting you and they state Windows driver is compatible but Vista asks for driver. Headset older"
Plantronics CS55 headset.
Greetings,
I also use a headset at work from the same company (Plantronics), If the battery is faulty it will not power and you can't use it.
The wiring has gone bad. Try re-connecting all wires.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Plantronics CS55 Wireless Headset
Hi, I have a Plantronics BackBeat 903+ and I have a big problem with it. It seems to have a bad contact some where in the left earpiece that every time I just touch it it turns off immediately. Can...
It sounds like there may be a short in the headset. If you are just touching the ear piece and then you hear nothing on that side. If that side has been damaged at all you might want to check for manufacture cracks or loose wiring. If your Plantronics Backbeat 903 is still under warranty you should be able to get another one.
Good luck from Headsets Direct!
Sep 05, 2011 | Plantronics Backbeat 903 Bluetooth...
How do you turn the PLantronics 520 off when not being used without losing the pairing
Press and hold the main button for three seconds to turn off the headset. Turning off the headset will not cause you to lose pairing with your cellphone. You can find more information here.
Mar 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Cannot hear other players
The only thing that I can think of is that there may be a broken or loose wire near the speakers. Make sure that your computer recognizes the headset, but if it is still under warranty you can have it replaced with Plantronics.
May 21, 2010 | Plantronics GameCom 367 Closed Ear Gaming...
Where can I download a driver for my plantronics dsp 500 headset for Vista?
Jan 19, 2010 | Plantronics DSP-500 Headset
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Dec 17, 2008 | Polycom SOUNDPOINT IP 501 SIP
Logitech Headset with micro phone
I got this from another page here:
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Mar 21, 2008 | Logitech (980590-0403)
Right speaker has a shorrt
Access screws on headphones are sometimes under the ear padding, or maybe on the opposite side under a sticker or label. Sometimes the wire will have come loose from the internal speaker, or it could be the external cable has been abused enough that the copper strands inside have separated.
Feb 28, 2007 | Plantronics GameCom 1 Consumer Headset
ITunes or sound card line in with my USB Plantronics DSP-500 headset
Jan 04, 2007 | Plantronics DSP-500 Headset
Plantronics (6440201) Professional Headset Logo
62 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
