I have an hp1055cm plotter that is leaving streaks on the page i.e. it makes a clean first pass and on the second pass (as the print progresses)it is like the head does not reach the paper and leaves the second pass light. I have changed the printheads and the problem persists. When the plotter is cold, it will complete 3/4 of the print job successfully and then the streaking begins. As the plotter is used more the streaking occurs shortly after the print job begins. Any suggestions?
    Problem Solver:
  • 28 Answers
Configuring the HP1055CM Driver Right click on the icon for the plotter (for WinXP, go to Start -> Printers and Faxes) and select Properties. Make the following changes:
On the tab marked General, click on the Printing Preferences button.
In the window that pops up, select the Paper/Quality tab choose Roll Feed for the Paper Source. Next, click on the Advanced button:
• Under the section called Graphic, click the down arrow next to ICM Method and choose "ICM handled by Host System".
•Under the section on Document Options, there is a section called Postscript Options. Click on the "+", then change "Optimize for Speed" to "Optimize for Portability". Also make sure the "PostScript Language Level" is set to 3.
• In the section Printer Features, set "Scale to:" to "No Change".
• If you wish, under Paper/Output, you can select a default paper size appropriate for the plotter: ARCH E (36in x 48in) seems reasonable. (Note that when you print from an application, you may want to adjust the paper size for your specific plot, and you should also set your document to an appropriate smaller size in the application.)
• Click on OK buttons until you get back to the main window for Properties.
On the properties tab marked Advanced, click on the radio button for Print Directly to Printer.
Also click on the Printing Defaults button, then the Advanced button. If you see a similar set of postscript options like you just went through above, repeat the process to set the ICM method, set postscript options to "Optimize for Portability" and Language Level to 3, change the paper size, and set "Scale to" to no change.
Click on OK buttons until you get back once more to the main window for Properties.
Under the property tab for Device settings, you should change the Output Protocol from ASCII to JPEG. (If there is no JPEG option, select Binary.) It is also helpful to change "Send CTRL-D at end of job" from YES to NO, but that isn't crucial. Under the section marked Installable Options, change the amount of installed memory from "Default" to the closest value below 96 MB, probably 80 MB. (The plotters actually have 96 MB, but since not all of that is available for user jobs, it's better to claim the smaller value. This is still larger than the "default" size, which is about 48 MB.)
Click OK.
Posted on Nov 06, 2008
Quality marks on a HP wide format
Ck to see if the "spittoon" is full. This is the box on one end (depending on model, that the plotter uses to clean the print head nozzles.
The newer plotters use pigmented ink which builds up in the "spittoon" and forms what looks like a small mountain of gunk. When the carriage assy passes over this, it picks up a little bit on the print head and bottom of the carriage assy and lays it down on the paper.
You can remove and clean the "spittoon" but it is a real mess and replacements are not very expensive. Remember to clean the bottoms of the print heads and carriage assy when you perform this repair.
May 28, 2013 | HEWLETT-PACKARD Hp - DESIGNJET Z3200 24IN...
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Phaser 3200 mfp laser printer leaves streaks on paper. First sheet is okay then rest get worst as printing continues.
One of two things.
If the streak is a line. No visible print in the streak, Then most likely the drun cleaning blade is bad and the drum unit will have to be replaced.
If the streaks are sort of reprint. a faint reprint of what is already on the page, then you need to replace the fuser.
Mar 25, 2010 | Xerox Phaser 3200MFP/N Laser Printer
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
1055cm plus locks up when printing... Display
did you check the trailing cables? check both ends (carriage and main pca)
Aug 05, 2009 | HP DesignJet 1050c plus InkJet Printer
My laser printer is leaving a big streak mark and i think its the roller how do i clean it?
If it is the same pattern on every page you print, it is your fuser; and there is no cleaning it. The fuser needs to be replaced.
May 28, 2009 | HP LaserJet 4250n Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Need repair on a HP1055CM plotter in Toledo Ohio
it is all one assembly. You will need to call a technician.
Jan 06, 2009 | HP DesignJet 1050c InkJet Printer
Want to print as close as possible to the edges of my 36'' HP 1055
if i remember correctly you can not do edge to edge on this printer. you may have the reached the outer limits with your current configuration. sorry this is not the answer you are looking for.
Nov 10, 2008 | HP DesignJet 1050c plus InkJet Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
348 people viewed this question
jasbo
jasbo
