Question about Toshiba Satellite A105 Notebook
Touchpad minimizes screen
When I double tap the touchpad it will constantly minimize my screen. This is so frustrating and really slows me down on my work. This happens wherever my cursor happens to be on the screen-it is not near the minimize button. Please help!
  • 37 Answers
Double check your settings for the touch pad. It could be set to do that under one of the settings. Or something internally could have gotten jogged or internally moved. If that is the case there isn't much you could do unless you got someone to look inside of it for you.
Posted on Nov 09, 2008
How can deactivate the pad?i dont want to click with a double touch...thanks
To turn the TouchPad on/off, quickly double-tap the TouchPad off indicator (the yellow LED) at the left top corner. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
This would disable the touchpad completely. Also, if you wish to disable just the double-click through double-tap, you can do this by going to the mouse/touchpad options from the control panel.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 17, 2011 | HEWLETT-PACKARD Probook 4530S
My curser is flicking all over the screen when I try to guide it
Disable the tapping feature of the touchpad.
Ensure the touchpad is not accidentally being touched while using the keyboard.
Slow down the speed of the pointer and the double-click speed.
Reinstall the touchpad drivers.
Sep 15, 2009 | Computers & Internet
My touchpad will not respond when I tap it anymore. I have to use the left button. I used to be able to tap or double tap the touchpad and it would act like the left mouse button. All of a sudden it...
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
My inspiron 1525 has a keyboard problem everytime i am typing it jumps back do you have any idea what's going on?
I've been struggling with this issue as well. I type really fast so I thought i was inadvertantly hitting the touchpad and moving the cursor. Maybe, maybe not. But today I discovered that changing one of the dafault settings for the touchpad has eliminating the jumping cursor trouble and I can type fast again without constantly checking my screen to see which line I'm actually typing in.
Here's what I did: Go to the control panel and the mouse and click on the icon for the touchpad and uncheck the touchpad setting "tap to click"
I also put my speed and sensitivity about in the mid-range. (Another suggestion that didn't work was to make my touchpad less sensitive).
Happy typing!
Feb 23, 2009 | Dell F3534 Touchpad
Toshiba A105-touchpad mouse intermintent problem
If you know where the touchpad/mouse driver is located on a recovery disk, I would 'delete' the mouse via the control Panel, reboot and see if Win will reinstall the driver from the restore partition or, ask for a disk as a source and you have to know where that driver is on the optical disk. I would locate the drivers on your recovery disks before you delete the current device.
Alternately, you might check Toshiba's support section for a touchpad driver for your OS and system and burn it onto a removable disk or thumb drive that you give to Win as a destination if asked.
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Toshiba satellite touchpad
READ THIS POST NOT THE OTHERS. you can configure each of the four corners of the TouchPad surface to act as different buttons when tapped. These corner regions are called Tap Zones. to disable this feature goto control panel, mouse, device settings, settings, tapping, tap zones, disable tap zones.
Feb 17, 2008 | Toshiba Satellite A135 Notebook
Screen minimizes when using the touch pad
If you touch the top right corner of the touchpad, it restores down the window you are currently in. The bottom right corner of the touchpad minimizes the window you are currently in. The bottom left corner of the touch pad brings up the start menu.
Nov 05, 2007 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite A105 Notebook Logo
216 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
