Question about Sharp R-203BW Microwave Oven
Sharp Carousel R-201EW 600 Watt
I haven't been able to find any info on this microwave oven. The "start" on the touchpad doesn't work all the time. There's power, the automatic features work (minute button, express defrost, etc.) Can the touchpad be replaced (Part number?) or would it be cheaper to just go buy a new oven? Thanks.......
  • pcorley Nov 24, 2007
    I have the same problem. Sometimes it works after I turn it off a while, but not always. I have returned one of these for a new one, and it is doing the same thing. In both cases, I had them about a month. If a solution can't be found, I will return this oven, as well, but I won't be bringing home any more Sharp products.
  • Anonymous Mar 14, 2014
    This touchmatic II glass touchpad keeps time but timing is erratic. Touch a number and it is liable to repeat one or two times before you can lift a finger. Oven runs, but timing is not accurate. I believe the part might be repaired as it most likely is a board component.
  • Sharp Master
  • 9,098 Answers
The keypad is available separately (you have to peel off the old one and stick the new one on) for about $36 plus shiping. It is also available preassembled with a new control panel frame and display for about $78 plus shipping. They are available from Tritronics at http:www.wehaveparts.com BUT - I would first suspect and check for a failing door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files via a Google search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide, but it's usually a door switch. If you still have a problem, please write back with more detail. Be safe!
Posted on Oct 14, 2006
  • DaveYoungEE Oct 25, 2010
    I had the exact same problem. I didn't want to pay $35 for a keypad on a $50 microwave, so I fixed it myself. The problem was with the switch. If you have some soldering capabilities, you can add another switch to act as your start button. I've posted the how-to here:http://www.youngcircuitdesigns.com/?p=49
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
Sharp carousel microwave touchpad start button is failing
may have to get a membrane switch........could be starting to fail, become intermittent...i've had to replace these on occasion.
Jul 22, 2012 | Microwave Ovens
Touch screen panel not working. in past unplugged and then plugged in again and it worked but now nothing
If you mean the display (the microwave works but no info on display) look here for a good diy thread:
http://nzlamb.wordpress.com/2010/04/10/sharp-carousel-microwave-lcd-repair/
Aug 12, 2011 | Sharp R-1750 Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
R-8350, No power to touchpad, but interior light works
The touchpad has its own fuse which has probably blown due to a surge perhaps related to the turning on of the fridge. Removing the cover from a microwave is potentially lethal due to the large capacitor to drive the magnetron. However, this is usually well away from the front panel. If you do venture in you should first unplug the unit and when the outer cover is removed, discharge the large capacitor with well insulated pliers -= otherwise keep well away from it. The fuse you are interested in is on the pc board behind the touchpad. Replace it with exactly the same fuse (usually a slow blow fuse).
Sep 22, 2009 | Microwave Ovens
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp Carousel Microwave oven
Assuming the unit works ok other than the display, you have a problem common to many Sharp models.
Check with www.microwavedisplay.com - lots of info on this issue and they offer a repair service for the boards at a very reasonable price.
Jul 10, 2008 | Sharp Microwave Ovens
I don't hear the fan, the carousel doesn't spin, nothing works but touchpad & light
It sounds like you may have an intermittent door switch or loose door switch mount.
Does it work differently when you wiggle the door?
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 19, 2007 | Sharp R-408HS Microwave Oven
Sharp R-203BW Microwave Oven Logo
618 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
