Lucky me - replaced batteries and all is well...
Which mouse is it...MX1000?
Check the power adapter...they give up very fast!'
If its broken take a nokia mobilphone adapter...
Mine does that from time to time as well. I am guessing it means the battery is getting old. Otherwise I start thinking a ghost in haunting my apartment and is using the mouse to get my attention.
SOURCE: red light keeps flashing on logitech mx700
Flisging red light: Your batteries need replacing.
SOURCE: My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
SOURCE: flashing light
It depends on the mouse. Sometimes the red light flashes to signify the processing of a command. If it is continually flashing, then you may want to replace the battery.
SOURCE: red light flashing top of logitech wireless
The flashing light could be a reflection from the LED and mirror or laser on the bottom of the mouse. I had this similar problem and it drove me nuts until I happened to hold it up to a mirror and noticed the flashing was in sync bot top and bottom of the mouse.
SOURCE: Logitech mouse is'nt working
You might try re-syncing the mouse with the wireless sender. Push the button on the sender (plugged into usb port usually) and then push the button on the bottom of the mouse.
In my case, the red light on the TOP of the mouse flashes for while, then the flashing stops, even though I'm continuing operations. Is this perhaps a very early warning that that the battery (batteries?) require replacement?
Or is a charger available from the manufacturer?
yep have same problem, when charging green lights go up as normal but then the red flashes. tried leaving revolution in charging docking bay all day but still only 1 green bar appeared on the mouse. not impressed as £50 mouse and started to have errors in under 1 year.
red light flashing where, on top or on the buttom??
