Question about JVC HX-C6 Shelf System
My system is protect status
When i turn on my system it tells me the status is in protect then shuts off.
    Problem Solver:
  • 17 Answers
Check the connections of the speaker wires. You may have a short between one of the pairs. Try disconnecting the extra speakers if nothing is obvious. It could be a damaged cord also.
Ted
Posted on Nov 06, 2008
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Showing a status and protect sign and shuts off
I would love to help you.
Please respond by PRESSING REPLY OR COMMENT
Did your electricity recently go out?
Bruce
Jan 13, 2011 | JVC MX-GT88 CD Shelf System
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
Everytime i turn on the stereo it shuts off an says protect
When sound system shows Protect that means it got problem in amplifier section and protection circuit is activated that shuts down system in safety. Qualified tech will fix it.
Jul 31, 2009 | JVC HX-C6 Shelf System
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
500.1 amp power lights blinks on and off
Protection mode; follow this link to get a manual for the amplifier: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Below information is from the manual:
Status Indicator Lights / Protection Circuitry
There are three status indicator lights on the top of the amplifier. These are as follows:1) "Power" (Green): lights to indicate that the amplifier is turned on and operating normally.
2) "Thermal" (Red): lights to indicate that the amplifier has exceeded its safe operating temperature, putting the amplifier into a self-protection mode, which reduces the power output of the amplifier. The red light will shut off and the amplifier will return to normal, full-power operating mode if the heat sink temperature drops back to a safe level.
3) "Low ω" (Amber): lights to indicate that the impedance of the speaker load connected to the amplifier is lower than the optimum impedance load range for the amplifier. When this light is on, a protection circuit engages and reduces the power output of the amplifier. The amber indicator will also light when a short-circuit is detected in the speaker wiring (this can be a short between the positive and negative speaker wires or between either speaker wire and the vehicle chassis).
There is only one condition that will shut down an undamaged 500/1v2 completely… If battery voltage drops below 10 volts, the entire amplifier will shut itself off. The green "Power" indicator on the top of the amplifier will turn off when this occurs. The amplifier will turn back on when voltage climbs back above 10 volts. This may happen in a rapid cycle when bass-heavy program material causes a weak charging system to dip below 10 volts momentarily. If this is happening in your system, have your charging system inspected to make sure it is working properly.
For information on troubleshooting this amplifier, refer to Appendix E (page 21).
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Protect flashing on screen
That is the system telling you it jhas shut down the amplifier circuit to protect itself from damage.
Check the speaker wires both at the back of the unit and at each of the speakers to see if any of them have come out or are touching anything they shouldn't be.
You may also have a blown speaker sending a short back down the line. So if you find no wires out of place, then disconnect each speaker and turn the unit off and on as you go until the message is not showing and sound is restored.
Apr 30, 2008 | Sony DAV-SA30 System
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC HX-C6 Shelf System Logo
156 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
