Sharp AR-C265P printer only prints one line of text
Our printer connects 9 separate computer stations. There is a delay time between the sending of a print job and the actual printing process. Sometimes the print job cancels itself and then only one or two lines of the text will print. Is it possible to somehow do away with the delay time?
  • nattyp Nov 16, 2008
    I have a similar problem. I have a HP Photosmart C4500 All in one printer that I continually connect and disconnect to my laptop with the USB cord it came with, so it is not always connected to my laptop (I don't know if that matters). But recently it just started to delay all of the printing jobs, completely random. I had not been doing anything different, but every time I go to print something it takes about 5-10 minutes to print after I click print on my computer. As a matter of fact, every action takes forever. I can't even check the ink levels on my computer.
    Is there a way to get rid of the delay and back to the immediate print it used to do?
    Thanks!
4 Suggested Answers
MUKHTAR
  • 2022 Answers
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Posted on Oct 06, 2007
Cogz
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
Files don't print on time, sometimes they print up to an hour later
Are you printing directly to the copier, or are you printing to it thru a server? Delays are often caused by server delays, or the size of the file you are printing, or problems in the driver loaded on your computer
Jan 28, 2010 | Sharp AR-M450N Copier
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
On sharp AR-163 I have white lines(text mising)from top to bottom ? It happens even when you print only
if you make a copy and the copy is ok but the print copy is bad . this sounds like you might have the wrong printer driver set up.
all sharp al-ar small copiers u must have the exact driver for coper model you can get them at sharpusa.com under personal copiers
Mar 11, 2009 | Sharp AR 163 Copier
Create fax from my HP window vista computer to Sharp AR-M162
Won't work with Vista unless you spend $100 for some fax program
Feb 20, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Dec 01, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Printing on my copier
Try copying and printing internal reports to check for quality. If those are fine, the problem is computer or network related. If those reports also come out bad, you have a hardware problem. Start by checking the toner supply. It may be out even though you have no message.
Jun 13, 2008 | Sharp Office Equipment & Supplies
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
285 people viewed this question
jasbo
jasbo
