Question about Whirlpool Duet GHW9150P Front Load Washer
My Front loader Washer has plastic shavings and it is clickin when it spins
When ever the was spins is clicks even in was mode. between the fron door and the metal basket I can see the plastic out cover that is has a shaved lip and its sitting about 1/2 away from the front. A few months ago I paid to have the Pump replaced and now this. I have two bed wetters and my husband is deployed. Should i just get a new washer for christmas? What should i have the Technician check for to make sure I can wait a while before it has to be replaced.
    Genius:
  • 1,447 Answers
Hi-
1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn’t, the belt may be loose or broken. If you’re fairly handy, tighten or replace the belt; otherwise call an appliance repairperson
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
Hope this helps
Posted on Nov 06, 2008
    Genius:
  • 2,035 Answers
Check for any worn on the side of the washer as there could contact washer drum and the body which cause clicking sound ..Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details ..
Good luck....
  • 958 Answers
Kindly open the door and inspect the drum and the rubber gasket of the door. there could be clothes or plastic lining that has come detached that is hitting the drum as it turns.
please inspect the interior thoroughly. check the drum as you manually turn it.
tnx 4 using fixya,
drcool
    Genius:
  • 3,422 Answers
If it's clicking the clutch is dragging causing an extra load on the motor and the motor will click on and off. But a bad wire connection will also make a motor click as well as something caught in between the inner and outer tubs like a rag or something. A bad motor will also cause a clicking sound it will be clicking and studdering not getting into a full spin but will wash normally
  • Priya darshan Nov 06, 2008
    If this is under warranty then get it repaired.
Why does my washer (maytag mah5500bww front loader) make noise during the wash/rinse cycles but not during the spin.?
The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on the upper hose hitting the top cover ir a plastic injector mold standoff on the outer tub bearing housing, also a flat spot in the belt could cause a tapping noise. Something between the outer tub and wash basket. I have had to remove items lodged in the drain tube between the pump and tub, like bra under wires. Sometimes you can squeeze the tube and feel objects the ate lodged. I always take the tube off the tub side and run my finger all the way down to the pump impeller to make sure. I also check the I can spin the impeller and the nothing is in the pump. Hard to say with out being there. Where do you think the noise is coming from top , bottom , left , or right side?
Apr 30, 2014 | Maytag Neptune MAH5500B Front Load Washer
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Kenmore HE 2 Plus front end loader washing machine has a load and when I open the door water pours out. It will NOT spin
since front loader wont spin till its empty
id be willing to b et you have a clog in the pump
get a few towels
and spread em out in front of the machine
take off the fron toe kick 3 T-20 screws on front lip bottom
you should see the trap cleanout dead center
turn the handle 1/2 tun and pull straigt out...
be advised the washer will dump
you now have the sump in your hand ensure it and the pump inside are clean
reassemble and test
use 1 tablespoon of soap no more
suds will mess this machine up
Oct 06, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
E20
the door won't lock, then i broke the grey thing that the door prong or latch locks into by slaming the door. its a little plastic grey hole hole. i don't see what holds the grey plastic thing in the hole. or how to order it. can you help. ? but the door wouldn't lock before that, i think the 3 and 4 year old kids play hanging on the door. how do you fix it. 2006 afinity fron loader washer. thank you. cheryl
Oct 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washer
one of the welds on your inner stainless steal tub may have broke causing the drop of your tub.  The tub has a warranty on it but the labor to put it in is around 3hrs give or take any hour.
Oct 23, 2007 | Frigidaire GLTR1670A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
