Question about Zanussi Washing Machines
Making scraping sound when spinning - Zanussi Washing Machines
    Genius:
  • 1,239 Answers
Hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Posted on Nov 06, 2008
Can I safely use my washer if I hear something metal scraping during spin cycle?
You can, but I wouldn't. The outer skin of the drum is made of plastic. If it is a coin, it could dislodge, get caught again in mid spin and punch a hole straight through the plastic.
Get a flashlight and look between the seal and the outer drum when you open the door.
Jan 24, 2016 | Frigidaire Washing Machines
Will not spin loud noise
Need a full model #. Describe the noise; is it a banging, scraping, whirring, etc? Does it make the sound when it should be agitating and/or spinning? Has it run fine until this incedent?
Thanks.
Jan 07, 2013 | Washing Machines
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Scraping sound when you spin the drum by hand. The washer is two years old. front loader affinity model.
does the drum move as you spin it (if so poss stuts) makes a scrapping sound
Just check to see if the drum moves more than it should
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Scraping, thumping, and whining sound as the washer drum spins. sounds like something may be loose inside. sounds like a loose belt squeeling?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 19, 2011 | Frigidaire Washing Machines
Maytag washer noise
Hello, If its making a loud squeeking/scraping noise, in my maytag that i repaired, the problem was the waterpump. If you turn the washer on it's side, you will see that it has a belt with three pully's on the bottom. One pulley is connected to the waterpump and right where the pulley meets the metal plate it's connected to, there should be a gold2_bing.gif coupling. This coupling sometimes comes loose and scrapes the metal plate on spin cycle (when the pulley is spinning) which causes the scraping/squeeking sound. If this is the case, you will see where the coupling has scraped a groove into the metal plate. The coupling will eventually catch while spinning and break entirely. The cheapest new water pump is $80.
Thanks
May 19, 2010 | Washing Machines
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
Washer makes loud scraping sound
Could very well be the pump as well. These pumps have been notoriously bad for the pully shaft housing slipping down and hitting the pump pully. More that likely your problem.
Jul 31, 2008 | Maytag Performa PAV2200
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Washing Machines Logo
133 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
