Question about E-Machines eMachines Desktop PC
T6216 CAN'T USE CD BURNER ERROR MESSAGES INDICATES NO CD DRIVE
T6216 NO CD DRIVE BUT WORKED 3 DAYS AGO! WANT READ ANY CDS BUT PLAYS MUSIC ON MEDIA PLAYER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Sounds like your CD drive is gone. Try inserting a program cd and see if it reads it. You can also switch the cable attached to the cd drive. Make sure you get a power light on the cd drive when you start the PC, if not you can try a different power connector from the power supply. Hope this helps.
Posted on Nov 06, 2008
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer...
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Regards,
fossildude
Mar 15, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Sir, i am having HCL laptop with windowsvista home ,whenever i insert dvd or music cds in my drive the error message comes "media in cd drive is not readable " the cd gets ejected it can't read please let...
http://www.kellys-korner-xp.com/xp_resources.htm
support.microsoft.com/kb/306318
support.microsoft.com/kb/308012
Those websites above show you everything to do with troubleshooting the problem as you will learn, there are many,many causes.& things to check, and try.
Mar 23, 2010 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
My MATSHITA DVD-RAM UJ870QJ ATA will not recognise an audio cd
i tried this and it worked when nothing else would.
http://sites.google.com/site/matshdvdfix/
Feb 21, 2010 | Acer Computers & Internet
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
MY PC no longer "burns" cds-but there is no "error" message
My only suggestion is to borrow another burner if possible and see if you get the same error with with that one. This will be the simplest way to determine if you have a software problem or if your burner has a fault.
Dec 05, 2008 | Matrix 226R (VPR226R) PC Desktop
Drive E wont read media
You need to replace the optical drive as it is no longer working.
Jul 06, 2008 | Compaq Presario 5000 PC Desktop
HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Jun 28, 2008 | Computers & Internet
AMSUNG DVD WRITER PROGRAMME DISK ( NERO, BG68-01317A REV.00 )
IF you are burn youor CD make sure is read and writeable drive if not
get a dvd burner or cd burner a dvd is for dvd CD rewriteable
a cd is just regular CD blank CD for both make sure format when your computer
has detect 14x or 16x 700GB storage...
Feb 01, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
E-Machines eMachines Desktop PC Logo
89 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
