Question about Belkin Computers & Internet
Im try to set up an wireless connection but it always seams to have a problem, one of them is that the sistem says that i have an ip comflict! what can i do?
    Problem Solver:
  • 18 Answers
Hi
Your problem is that two or more devices are trying to access your router using the same IP thus creating an IP Conflict...Knowing that one IP can only belong to one device.
First you need to access your router.
Open an internet window and type in the router IP which should normally be 192.168.0.1 or 192.168.0.0
Type in your username and password
now that you're in, you can basically increase your IP range to give access to other device on your network. You can also assign specific IPs(within the setup range) to any particular device.
In doing so each the router will recognize and connect with any device with a specific IP thus solving your IP conflict.
Hope everything works fine
Cheers
Posted on Nov 06, 2008
    Novelist:
  • 173 Answers
If your getting that message on your computer that means the IP address that your computer acquied from your serverrouter has a duplicate in the network. The very first thing that you need to check is whethere your computer has a an IP address that is manually assigned to it, to check this just go to Network Connections under Control Panel(assuming your computer runs on Windows XP). Right click on the Wireless Connection icon and go to properties, under Local Area Network Properties you will find several check marks under This device uses the following; Client for Microsoft, File and Printer Sharing, QoS Packet Scheduler etc... Look for and highlight Internet Protocol(TCP/IP) and click Properties, under the TCP/IP Properties you have 2 option for both IP and DNS server. Make sure both is set to obtain. If your still getting the same message Right click on Wireless Connection and choose repair so tha your router/server will provide a new unique IP address, wel that will usually resolve the IP address conflict on your computer.
Limited acess with wifi bluetooth error with Asus K55VD-SX405
If windows7 open network and sharing center then manage wireless networks then remove all networks there then click on change adapter settings right click your wireless LAN \proprieties\TCP/IP V4 use automatic IP and dns \ok\ok then disable enable it then try to connect.......Good Luck
Feb 03, 2013 | Computers & Internet
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of 192.168.0.3 IP and a Default Gateway address of 192.168.0.1 you can set the Belkin with any adderss between 192.168.0.10 & 192.168.0.254. Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
Belkin 54g Wireless DSL/Cable Router (DHF5D72304): Im trying to hook my wii up to the internet and it...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings change channel type to 3 or 6 or 11 and save so you get better signal.
Then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 17, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I have been connected to the internet wirelessly for the past 7 months with no problems at all now i connnect within an hour or so it states im connected but with limited connectivety what does this mean n...
The problem is with the wireless router it seams .Limited connectivity means the laptop wifi does not able to receive good quality signals from the wireless router.check the wireless router and ensure it was working well
Mar 08, 2010 | ASUS F3E-AP183E T7250/2.0/160/1G/15/VBS PC...
Hi. i have been trying to secure my wireless connection for some time now. i tried doing what has been instructed but so far, im not getting the window that would enable me to do just that. would...
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Mar 05, 2010 | D-Link High-Speed 802.11g Wireless PCI...
Hi im having bit trouble with my router it is a (f5d7231-4 the wireless connection works fine even though signal low,yet when i try connect another comp from it i keep gettin an ip conflictkeeps telling me...
Hello
do you have dhcp on your router or do you have static ip:n on your computers? sounds like you have same ipn on both computers. you should change it to DHCP. go control panel networks settings then rightclick on your connection and properties click tcp/ipv4 settings and properties, mark optain an ip address automatically, also set dns automatically.
Jul 02, 2009 | Belkin (F5D7231-4) Wireless Router
Xbox 360 ics apipa
you need to set static ip's for the xbox 360 and the lan that is on the pc, easy to bride the two connections on your computer, then set static on the lan that the 360 is plugged in to, example:
360's static settings:
ip: 192.168.1.14 sub: 255.255.255.0 gateway 192.168.1.1 ------------------------------- computers settings:
ip 192.168.1.15 sub 255.255.255.0 gateway 192.168.1.1
Feb 05, 2009 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
2wire 2700 HG - Many problems and can't reset it!
you need to set up the 2 wire using an RJ45 ethernet cable and not wirelessly initially, and you need to set your ethernet lan adapter to obtain an ip address automatically and then type the default 192.168.1.254 in your browser to get in the settings and then set or enable dhcp, and also enable wireless as by default it is dissabled and check the the adsl light is lit
Some 2wire routers normally come with WPA-PSK security already set up with the passkey on a sticker on the side of the router, so that may be why it stays set when you reset it.
Check that your wireles adapter is using the same type of security when you enter the passkey when wirelessly connecting.
Nov 21, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
74 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
