Question about Hitachi 50UX26B/27K 50" Rear Projection Television
50" Hitachi rear projection TV problem twisty lines
My TV has all 3 colors but the bands of colors are twisted together horizontally in bands across the middle of the screen and about 3" high, no normal sound volume unless turned up high, sometimes see letters mixed in with the bands twisted together, then over time the whole thing goes away to just a little bit of letters or bands showing on the right side. This tv is about 15 yrs old but has had only one problem about 2 yrs ago, replaced power module, until this started. Magic focus does nothing, turning it off, letting it reset or cool off does nothing, and I've tested the satellite receiver on another tv and its fine. This TV has not been moved or anything in a long time. What's wrong and how can we fix it? My hubby can fix things very well, just needs to know what to do or look for, if anything can be done.
    Genius:
  • 1,550 Answers
It sounds to be a convergence problem .
You need to replace convergence ic .
Posted on Nov 06, 2008
  • SAM ANDERSON Nov 06, 2008
    You need to change two STK392-110 convergence amplifiers.
Have a 50fx48b Hitachi TV, screen flickers, gets wavy and goes to horizontal line, smack top of tv and it goes back to normal.
This problem is a couple of bad caps in the vertical and horizontal sweep area, just can't remember which. It use to be a 220uf cap that needs changing.
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Has pink/green horizontal line across top l corner
Hi,if your tv is dlp or lcd you will need to replace the light engine that's in charge of creating the image and colors, and when bad you 'll get discoloration or lines across image.
Oct 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 53SDX20B
Hi, common issue but difficult for lay person to fix, tube sockets and spark gaps on crt boards need to be cleaned, hard to get at but most local shops have probably done more than once, if you want to attempt get back to me & I`ll explain further, video-tek
Jun 09, 2009 | Hitachi 53SDX20B 53" Rear Projection...
1996 Hitachi 50FX18B 50"
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 24, 2008 | Hitachi 50FX18B/19K 50" Rear Projection...
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
CONVERGENCE
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Dec 14, 2007 | Hitachi 53SDX89B 53" Rear Projection...
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Open Questions:
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
