Question about Samsung Syncmaster 940BW LCD Monitor
How to open the Samsung Sycnmaster 940BW housing?
One of the mounting brackets has broken off inside and I am afraid it may short out something if I apply power to it now. Do you know you to open the housing? There are no obvious screws to remove. Thanks for any guidance you can offer.
5 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: How do I open my Samsung 2233sw LCD monitor?
I just installed a lot of this model at the office, it should be under warranty. If it failed and you try to get it fix under warranty, they may be able to tell that it has been tampered with.
Posted on Apr 10, 2010
  • 14 Answers
SOURCE: how to open CRT samsung
its easy actually..there r two locks on top of monitor. u can see minute space betweem backcover and front...insert any thin bt hard strip or pin and push them back simultaneosly pull back the cover.it would work
Posted on Sep 07, 2010
budmrtn
  • 11361 Answers
SOURCE: good day! The problem with
More likely to be bad caps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 12, 2010
  • 217 Answers
SOURCE: I purchased a used T260HD Samsung monitor / tv,
There will be 4 screws behind the monitor. Loosen it slowly to remove the bracket.
Thank you
Posted on Jan 05, 2011
pctech1
  • 1940 Answers
SOURCE: I have a Samsung 932B
It is best to take the monitor to a TV, Monitor, or Electronics Repair Shop when problems like this occur. If the image is seen on the screen, but is very dark, then the backlights for the screen have gone bad and the screen must be replaced. If there is no image on the screen, the problem could be with the display control board.
Posted on Feb 10, 2011
I have bathroom fan. all that is left is the housing 10"x10"x7 3/4"D.I cannot identify manufacturer without tearing ceiling apart.
The previous tenant removed fan and grille and threw them away all that is left is the housing.Im trying to identify fan type so I don't have to tear ceiling apart
May 15, 2016 | Dryers
Were does engine bracket 1f2E 10B315 BA GO ON 02 FORD WINDSTAR MINIVAN
The short 90 degree side of bracket bolts to the upper left a/c compressor mounting hole and the other bolts up to the alternator mount. This provides support for the compressor under load so it won't crack housing. Without it only four long skinny bolts hold it on.
Apr 03, 2014 | Cars & Trucks
Good day! The problem with my samsung lcd monitor model no. sycnmaster 540N, it takes 30mins to 1hr before displaying, but the power button blue light is blinking softly. I was able to ask this to the...
Dec 12, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Got votage supply in, but no display.
You have to do some caps checking and voltage checking.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 10, 2010 | Samsung Syncmaster 940BW LCD Monitor
Monitor will not turn on !
Look for bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Aug 08, 2010 | Samsung Syncmaster 940BW LCD Monitor
When i turn my computer on it takes about 15 minutes plus, for the monitor , to turn on. Same is happening if the screen goes to sleep for long time (ex. 1 - 2 hours). Because I'm working on video I might...
Check the DC filter caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 25, 2010 | Samsung Syncmaster 940BW LCD Monitor
My samsunn lcd monitor no display no come out. what's the problem?
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 05, 2010 | Samsung Syncmaster 940BW LCD Monitor
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 01, 2009 | Kenmore 63942 Dryer
Syncmaster 940bw buttons on front of monitor stoped working completely
You mean monitor is now dead or does it come on and front panel buttons are not usable?
Samir
Jun 06, 2008 | Samsung Syncmaster 940BW LCD Monitor
Won't start. The start light flashes. Timer appears to be functioning.
You could have a couple of things going on that may cause your symptoms. First of all, unplug the dryer. If you can access the inside of the dryer check to see if the dryer belt is broken. On some dryer models if the dryer belt breaks a "broken belt relay" on the idler pulley near the motor will trip causing the motor to shut down. This is to prevent a broken belt from becoming wrapped around the motor shaft. Another possibility is a blown thermal fuse or thermal cut-out. Some dryer models have a thermal fuse mounted on the exhaust vent housing and is white in color. This should read a short. There should be a thermal cut-out mounted on the heating element housing as well. There will be a hi-limit thermostat mounted near it. The thermostat will have a resistance reading (can't remember exactly what it is), and the thermal cut-out should read a short. If the thermal c/o is bad, replace the hi-limit thermostat as well. Now if you have a thermal fuse or thermal cut-out problem, they generally blow for a reason. Check your dryer ducting for proper air flow and make sure its not clogged full of lint. Normally, a thermal problem is associated with your dryer overheating. Good luck and let me know if this helps.
Jun 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Samsung Syncmaster 940BW LCD Monitor Logo
391 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
