Question about Emerson (CKD2330) CD Player
Standby mode and display glitch??
I cannot read the time on the clock display. This was fine when I first plugged it in. The numbers are barely visible if I try looking from a strange and extreme angle. Also, when I go into standby mode nothing happens...it looks as though the faint clock numbers are scrolling through the times continually though. It was like this out of the box.
SOURCE: Emerson AV101 System
there is a reset button on the back u will need a ball point pen to push it in and it is very small.
Posted on Nov 19, 2007
  • 55 Answers
SOURCE: stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
Posted on May 18, 2009
  • 814 Answers
SOURCE: Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Posted on Jun 12, 2009
  • 814 Answers
SOURCE: display keeps going on and off
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
SOURCE: My Emerson stereo MS9903TTC won't turn on. It was
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Posted on Mar 28, 2010
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Bush PDVD-312 not reading discs
remove the cover then look for a burnt parts like capacitor or a transformer or an stuck up in the loading tray.
Oct 14, 2012 | Televison & Video
The LED display is barely visible. Both for Timer and Oven Temp.
Problem with Frigidaire CFEB27S2AB2 Electric Wall Oven.
My LED display on my clock has the 3rd number not showing up all the
light. Sample 10:30 the 3 on the top is not light. What is the problem
Jan 07, 2011 | Frigidaire FEB27S5A Electric Single Oven
I have a ten year old Proton Clock Radio RS-330, now Sangean RS-330. The flourescent display seems to be about half out, and the time display is barely visible in the dark. Can this be repaired, and by...
The display itself may not be the problem which may be related to the power supply for it instead. Some technical skills and a decent multimeter is the minimum you should have to determine the source of the problem.
If you are looking for a local service company, you should always post your ZIP code so a tech in your area is likely to respond.
Jun 28, 2010 | Proton R5A Clock Radio
THE DISPLAY PANEL ON MY OVEN DOES NOT DISPLAY THE
replace defected control board.some of the cap on control board leak.
Jan 27, 2010 | Thermador SMW272 Electric Double Oven
The CD player on my Sony Dream Machine FM/AM CD clock radio will not play. I have left the CD compartment open per the troubleshooting instructions in the manual, to remove moisture but to no avail. When I...
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
Jun 26, 2009 | Sony Dual-Alarm AM/FM Clock Radio with...
LCD screen is messed up
I can't set the time. Can you give me the instructions
Dec 08, 2008 | KNG America Mcqueen (028623) Clock Radio
HTC P3400i LCD Problem
My Htc p3400i phone can't share fast informnation via Bluetooth
Nov 29, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Display went out. Replaced it with new display unit.
Check you part numbers , if same the new one can be bad even the clock displays
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Emerson (CKD2330) CD Player Logo
41 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
