Question about Estate TS25AFXK Side by Side Refrigerator
Estate Refridgerator I have an Estate double door refridgerator. The temperature is above normal on both sides. Anything I can do to fix? Thanks Steven@avevolution.com
    Genius:
  • 1,239 Answers
Hi this component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.
Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
Posted on Nov 06, 2008
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Every time I close the refridgerator side the freeze side opens, how do I fix it.
Hello ttd1977 - Often when one door is closed and the other opens, it is because either the hinges are damaged or the refrigerator has a poor door sealed. Trying checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. If the gasket is not sealing properly, it may possibly near replacing. Since there are cost differences in parts it is always a good idea to have a certified technician properly diagnosis your appliance. Thanks for allowing me to help you.
Apr 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
Refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
LG Refridgerator GR-131R. Out of the
Good day.
Seems like your thermostat went shorted that is why you cant control the temperature anymore.
chris
Mar 11, 2008 | Refrigerators
Estate TS25AFXK Side by Side Refrigerator Logo
101 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
