Question about Dell Latitude D600 Notebook
My laptop doesn't Boot
My laptor refuse to come each time i try to restart it, but rather it blinks a greenlight with Esncription of a key for some seconds and then goes off.
  • 1 more comment
  • dirtracer69 Nov 16, 2008
    i also have the same problem. the light that turns on on mine is the one on the right corner of the base of the laptop where there is a power light, battry light, bluetooth light, and harddrive light. when the computer is turned off and the power button is pressed only the light i described turns on, but when the computer does turn on the power and harddrive light is suppose to turn on, and you also hear a clicking noise from the harddrive. It does not always do this though, only about 75% of the time.
  • Ldouglascox Dec 26, 2008
    Toshiba laptop was left on all night with only battery. Now laptop will not power up. red battery light flashes 4 times even after being connected to AC adapter for more than one hour. Ldouglas
  • Christopher Ruiz May 11, 2010
    I can try to actually help you on this.. but first do you have the same problem while turning ON the
    computer from a computer shutdown? Also which green light are you referring to, is that the power button
    light or the power indicate light that looks like the picture below..
    http://support.dell.com/support/edocs/mo...">
Geekman, my hardrive only does this 50-75% of the time. It does turn on after fighting with it for 10 - 15 minutes. Usually the way i get it to turn on is when the hard drive does not turn on i smack the area in which the hard drive is located, or i will spin the computer to get the momentum to get the hard drive spinning. Once on, it will run all day with no problems. I have a new hard drive for it, but i don't have a reinstall disk for xp as i bought the laptop used.
Posted on Nov 19, 2008
  • Dell Master
  • 32,281 Answers
Hi chris2connie,
The Key symbol at the top left hand corner of the screen means that the laptop is protected with a password, you need the password to start the computer, if you got it second hand ask the person you got it from for the password..
Depending upon the brand of the laptop, the password can be stored in the BIOS, this password can be removed if the BIOS battery is removed, wait fot approx. 1 hour, insert the battery and configure the BIOS setting and the laptop is functional again.
If the password is stored in an EEPROM chip then your laptop is a piece of junk and the cost of a replacement motherboard would not be worth it (put your money towards a new laptop). If by luck you know of a knowledgeable hacker he/she may be able to help you out, it requires a bit of hardware and software to reprogram the EEPROM chip.
Hi dirtracer69,
Your problem is simpler, basically you have a faulty hard drive, the clicking sound is proof.
You can replace the hard drive, install the operating system software on the new hard drive with all the drivers for your hardware devices and your programs etc.
Chances are you have lost your data on the hard drive (hope you have backed up your data).
If you manage to get your laptop running for a short time, then you may be lucky to save your data before it crashes again.
Tx2000 hp laptop not booting up, all lights are on green except amber light from wireless button
Do you get anything on the screen at boot? When you removed the HDD did you test it? It powers up, but will not boot correct? Fan spins, LED's Blink? Battery charges? Can you get to BIOS or Boot Menu? Can you do a Restore/Recovery? If you insert a repair disk into the DVD/CD rom drive does it respond? Take a look at HP support page: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&cc=us&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0001&lc=en&product=3658348
Apr 01, 2013 | Computers & Internet
My lap top shut down and would not restart. I called the company and they said I needed to reinstall programs. They sent me two discs, but I cand get them to load.
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 15, 2013 | Dell inspiron 14r-n4110 laptop intel
Cruser keeps blinking.
Black screen with blinking curser?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 04, 2012 | Acer Aspire One Netbook 8.9" Notebook
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
Will an E-Systems 2512 Laptop refuse to start if its the battery is defunct
Take the battery out and try starting it with the power cord only. If it starts then there is your answer. If it doesn't start then either your power cord/charger is dead or your motherboard is.
Jun 19, 2012 | Computers & Internet
My Dell 2400 refuses to load windows xp
restart your computer
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope this helps you
Oct 31, 2011 | Dell Computers & Internet
How did i boot my toshiba satlilit pro
Here is a solution for your problem.Please follow the below steps to boot your laptop.
1. First of all insert the CD from which you want to boot your laptop. 2. Shut down your system. 3. Press the power and then start it again and press the "C" key to boot from the CD.
If this method doesn't work, you can try pressing F2 or F12 at startup and selecting the CD drive from the list of options.
If neither method works, hold the "Esc" key while restarting the computer and press F1 when prompted to access the BIOS. From there, you can change the boot order so that the computer attempts to boot from the CD before any other devices.
This will surely help you out.
Thanks you. Have a good day.
Aug 10, 2011 | Toshiba Satellite A60 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Cant install windows XP on my Toshiba Tecra S1 laptop.
Where did you get your disk from? It sounds like you may have a bad install disk?
Mar 25, 2009 | Toshiba Tecra S1 Notebook
Dell Latitude D600 Notebook Logo
331 people viewed this question
Alun Cox
