SOURCE: Print Head Alignment
Get the driver here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14428&prodoid=9935&infoType=Downloads&platform=All
SOURCE: blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
SOURCE: print alignment and cleaning heads
this is the utility present on epson printer software itself, go to control panel select printers, then select the c48 right click on it, go to printing preferences, then select maintenance
SOURCE: Epson Stylus CX5400 will not print. This printer
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
SOURCE: My print head doesn't seem to be able to align
Most printers have an align command. Your printer manual will tell you how to use it. Failing that, try right clicking on the printer icon at the bottom taskbar to see if you can find it in the menus there.
