My battery to my phone was pretty low then in the middle of me texting it just froze. So I took the battery out and put it back in and it wouldn't turn on. So i figured the battery died and charged it for a little while. Now when i turn it on it either just lights up or shows the motorola screen and shuts back off.
When you plug in the charger cable to your phone, make sure that you allow it to charge at least 2 hours, if your phone shuts off immediately after this amount of time, you likely need a new battery, they will wear out after a certain number of recharge cycles.. contact your motorola distributer or motorola website to purchase a replacement. Note do not accept "Non-Motorola Batteries or chargers as these are not guaranteed to provide the proper current necessary to safely recharge your battery, if you notice the battery getting Hot, then disconnect the charger immediately and let it cool, before removing and disposing. Remember it is normal for the battery to be warm to touch while charging or the phone itself is in use. but if it gets hot to the touch this is not normal, and the battery needs replaced..
SOURCE: online instruction manual (English) for Motorola Z3 Rizr
hi
have you tried the motorola web site they may have the download form there Motorola .
riz.
SOURCE: firmware for motorola rizr z3
T-Mobile SW Update
For other updates follow you regional/carrier SW suport on www.Motorola.com
SOURCE: how to replace the motorola rizr z3 outer navigation slide small
http://modmymoto.com/wiki/index.php/Razr_v3_Full_Housing_Change
follow the steps given in this site... think it ll help u out to change ur mobile's housing
SOURCE: Unlock code for USA AT&T Motorola RIZR Z3 IMEI # 353616012240905
myuncle I found him using an website which helped him a lot to unlock his phone althoughI had unlocked it before and I paid a lot for it but its very efficient processso go through itmobile unlocking code
my phone's screen had broke and i got it fixed christmas week and when i got it back it wouldnt turn off or on i managed to tirck when i put the charger in but i did it again and now the screen just lights up and shuts off
