Question about Panasonic PV-C2022 20 in. TV/VCR Combo
MODEL PV-M2021, TV/VVCR HOOKED TO CABLE,
TRYING TO GET CABLE CHANNELS TO WORK, VCR DOES NOT WORK & TIMER LIGHT FLASHING, JUST WANT CHAnnels to work
3 Suggested Answers
  • 1003 Answers
SOURCE: Panasonic PV-M2738 flashing light
A BAD PCB (power control board) maybe cheaper to buy new combo
Posted on Jan 17, 2008
  • 9 Answers
SOURCE: I have a Panasonic TV/VCR combo my kids deleted
A universal remote can be programmed for your tv/vcr. Then you can access the menu to auto program your tv. Otherwise there should be a button on the front that allows you to access the menu and then auto program the unit.
Posted on Feb 18, 2009
How do i hook it up to my tv
The simplest way is to connect the screw on connector marked Output on the back of the VCR to the screw on connector marked antenna or cable input on the back of the TV. There will be either a switch or menu item on the VCR where you chose to have it output on channel 3 or 4. Chose which you prefer and then tune the TV to that channel.
Sep 30, 2014 | Panasonic Pv-9400 Vhs Vcr Hi-fi Video...
My panasonic tv dvd vvcr combo remte rplacement i have tryed universals remotes but they don't work
Return the universal remote,if all ur tv universal codes of ur tv on the owner manual,don't work.Try website like Remotes.com to buy the tv original remote or very close capatible to it.Yes,it cost double even tripple the prices of any niversal remotes,but these remotes are 100% it will work with ur tv,because it the same or compatible as a orginal remote would.
May 31, 2011 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
I'm not sure how to connect my Toshiba SE-R0346 to my Sanyo TV. I plugged the cable line into the "Antenna in" port & then another cable line from "Antenna Out" to my TV. If I...
Exactly as you have done is fine all you need to do now is play the tape, (so you know what to look for when it is displayed on the screen), decide which channel you want to view the vVCR through, say 9, select the channel and set the TV to search tune on that channel. Store it when your taped programme appears.
Alternatively, have the set up as you have described and press auto install. That will retune the whole of the TV and include the VCR.
Hope this helps.
Nov 03, 2010 | Toshiba Televison & Video
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
I have a Panasonic TV/VCR combo my kids deleted all the channels out of it, and we don't have the remote. Tried getting codes from the cable company but didn't work. Model # PV-C1321A Model # 120V AC60Hz...
Feb 18, 2009 | Panasonic PV-C1321 13 in. TV/VCR Combo
Sharp VCR hooked up to cable tv, i/p to vcr then out to tv.
I believe that I have the solution to that problem... When you are hooked up to cable or dish and use a VCR, you MUST have the program you wish to tape playing on the Cable or dish program, therefore the VCR needs to be tuned to channel 3 or 4 {whichever is the unused channel in your area) I believe that all you have to do is make sure that the TV is tuned to the channel you wish to tape and program the VCR to Channel 3 (at my area) or channel 4.
I hope this works for you. I have VCRs hooked up to all my sets and this is how mine work.
annabanana
Jan 23, 2009 | Televison & Video
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Sep 01, 2008 | Televison & Video
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Panasonic PV-C2022 20 in. TV/VCR Combo Logo
190 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
