Question about Sony KP-61HS10 61" Rear Projection Television
TV keeps turning off - only red screen
My kdis were watching tv today and then started screaming and yelling. I went in and the whole screen was RED. I could still make out a faint image through the red but then the red got darker and the tv turned itself off. Now whenever I turn it back on it starts at light red and gets darker and turns itself off. The sound is working. Any suggestons?
  • 39 Answers
Red c.r.t is faulty ,needs replacement.
Posted on Dec 20, 2007
SOURCE:
Why does plasma TV have no picture?
What brand and model # is the tv? This is very important as far as researching your problem. You probably aren't the first or the only person with this problem. There are typically four to 5 boards including an x main, a y main, power board and others. Sometimes easy stuff like capacitors or fet's go bad and you can fix it yourself pending your soldering abilities. Sometimes whole processors go bad or entire boards and these need to be replaced. Sometimes people want to fix sometimes they want brand new
Jul 07, 2015 | Televison & Video
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Hdtv has a red screen
Looks like you got some convergency issues there, I would consult a local repair place like www.teexp.com put in your zip code and see if they service your area and TV.
They can also give you a estimate on how much it will cost to get it repaired.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 12, 2009 | Hitachi 57S715 57" Rear Projection HDTV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Screen keeps blinking red
check the menu and see it it hase the same issue if sone one of the main boards are bad.
May 27, 2008 | Philips 42PF9630A 42 in. Plasma Television
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
Sony KP-61HS10 61" Rear Projection Television Logo
289 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
