Question about Sony SDM HS93 19" LCD Monitor
Soft Controls on monitor are inoperable
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim. Sometimes the monitor comes on with interference lines or different colored hues. I think this all stems from the soft controls themselves. What can I replace to make it work normally?
3 Suggested Answers
SOURCE: Sony SDM HS93
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
iamthehipster@yahoo.com
Posted on Dec 27, 2008
ticthak
  • 43 Answers
Most likely both problems above are due to dirt/smoke/crud on the keypads; in the case of power, plugging and unplugging is workable albeit obnoxious, and COULD shorten the life of the monitor. More than one button means it's probably time for a teardown and cleaning, which could take 2 hours, but almost certainly more than 1.
Posted on Feb 11, 2013
Monitor light up then shut down itself
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Sony SDM HS93 19" LCD Monitor
Power light lights up but monitor dont come on
HI,Dear Friends..
Do you hear the hard drive working and see the LED flickering? As you can't see the screen to log on, Windows will stop at that point.
> If you have a spare PC monitor and VGA to VGA lead check it.
> And your keyboard working properly or not, if NUMLOCK light on it means your hard drive is OK.
> Your Monitor light on/off regular, or not? if light regular blink then power come but VGA section not working. So please contact Monitor Engineer.
Thanks...
Feb 13, 2013 | Sony SDM-HS93 19" LCD Monitor
I have a Sony SDM-HS93 (Black) 19 I turn the monitor on and it flashes on then off and on again. does this continually.. any answer for me? I have opened the back and checked capacitors and all look...
It may have bad lamp assemblies, you need the inverter tester lamp to verify. See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
This is common problem with the 17" version also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 10, 2011 | Sony SDM-HS93 19" LCD Monitor
I have a SONY SDM-HS93 LCD monitor, Maybe Monitor receiverd an electric overstress, so the screen displayed but screen disappeared after few seconds. And if I turn it off & turn it on again, it turns...
Siny LCD Monitor is so expensive. <a href="http//www.wholesaleeshop.com.au/LCD-Monitor/index.php?keywords=philips">Philips LCD Monitor</a> is good!
Nov 02, 2010 | Sony SDM-HS93 19" LCD Monitor
Sony SDM HS73 ''turns off''
One thing I know for sure on this model HS73/HS93 is that the backlight assemblies failed due to poor soldering works. This may the problem with your monitor.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
It is very time consuming repair works that I doubt very much if repair shop will do the work.
Apr 19, 2010 | Computers & Internet
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
G
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
Sony SDM HS93 19" LCD Monitor Logo
51 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
