Question about HP LaserJet 4 plus Printer
HP LASERJET 4 PRINTER
MY PRINTER IS DISPLAYING AN ERROR CODE "57 SERVICE" WHAT DOES THIS MEAN??????
    Problem Solver:
  • 15 Answers
The main motor can become jammed, make sure its running freely, this can be the done by lubricating the main motor's shaft.
The best soultion is correct, but the motor itself can jam, and carefully lubricate the motor's shaft, and move it till its free and this will restore the motor and machine will run again.
done this with many motors of diffrent kinds of machines, including fans.
Posted on Nov 08, 2008
  • dclarkchem
    dclarkchem Sep 04, 2012
    How do you get to the main motor? I've taken it apart from several angles, including removing the fuser, but don't know where it is located.
  • 24 Answers
Toner Cartridges can also slow the main motor to where it can display such a mssg. Remove the cartridge and shut the machine off. Then start it up with no toner in the printer.
Posted on Nov 07, 2008
    President:
  • HP Master
  • 1,314 Answers
57 (or 57.1) SERVICE Message (Main Motor
Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly
Posted on Nov 06, 2008
2 Suggested Answers
cene765
  • 787 Answers
SOURCE: 57 service error message. Wht does that mean? We
A fan failure was detected.Printer fan or Duplex fan.
1. Check the fan’s connector and make sure the fan is not blocked.
2. Replace the fan.
On older style printers this is often caused by a bad main motor. (Older style printer being printers with halogen heating elements in the fuser - 4, 4+, 5, 4si, 5si, etc).
Posted on Oct 19, 2009
Testimonial: "Fast response"
How to solve 57.01 error turn off then on in my hp color laserjet cp2025 printer
57.xxx codes almost always indicate a failed cooling fan. The fan will probably need to be replaced to get rid of the error code.
Sep 05, 2014 | HP Color Laserjet Cp2025 Printer Laserjet...
57 Service Error Code
Most likely a main motor problem, this is a major repair so you might need to get to get a printer service company to fix it.
Mar 04, 2011 | HP LaserJet 4 plus Printer
Had a paper jam - now removed but comes up with an error 5703
57.XX ERROR Control Panel Message 57.XX ERROR For help press c00244025.gif alternates with To continue turn off then on Description A temporary printing error occurred in one of the printer fans. Action Turn the printer power off and then on. If the message persists, contact an HP-authorized service or support provider. Click here to locate an HP-authorized service or support provider via the HP Web site at http://welcome.hp.com/country/us/en/wwcontact.html.
Feb 21, 2011 | HP LaserJet 2420 Printer
Gettining error 57.03 in hp laserjet 5200 printer
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Dec 22, 2010 | HP Office Equipment & Supplies
Error code: 50 service. What does this mean??
Blown quartz fuser lamp. Replacement kit available here for about $40.
Oct 21, 2009 | HP LaserJet 4 plus Printer
2. Replace the fan.
Oct 19, 2009 | HP LaserJet 4 plus Printer
57.03 error
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
MY HP LASERJET 3005 DISPLAY ERROR 49.2F9D
Its already discussed in one of the forums for Hp.
check :-
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Jun 04, 2009 | HP LaserJet P3005 Printer
49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Jan 21, 2009 | HP LaserJet 4350 Printer
REPAIR
Yemmitty,
According to the HP LaserJet 4 plus service guide. Your error code of 57.1 indicates the following;
1) The printer's gears are siezed
2) The DC controller or main motor is defective.
Nov 10, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
763 people viewed this question
Seeker5211
Seeker5211
