Question about Viking DTWL4848 Kitchen Hood
Viking 10 inch hood lights out
We have a viking range hood, similar to the VWH3048, the difference is ours has the 1200 blower. The other day, both of our lights went out. We thought it was strange that they went out at the same time, but we went ahead and changed the lights. To our dismay, the new lights didn't come on. Is this something that we can fix ourselves? Any ideas on what happened, my husband thinks that it is either a short or the sockets burned out. Any advice would be appreciated. I have the same problem but my hood is the vwh3648. All other controls function ok right now.
  • 59 Answers
It is more than likely the dimmer switch has gone bad and needs to be replaced
Posted on Mar 10, 2009
I'm just an average do-it-yourselfer....this was more intimidating than it really is. Go to www.allvikingparts.com as long as you know what model number you have the guys there will make sure you get the right part.
1) Throw the breaker to the circuit the lights are on2) Remove the grease traps and trim from the front section of the hood3) Remove the 3 sheet metal screws slowly from the hood....the hood will fold forwards about 6-8 inches...don't go too far4) Disconnect the existing dimmer...I found it was easier to work with by disconnecting the red wire first, then carefully push the on/off switch from behind to disconnect the black wire. Remove the dial and carefully unscrew the nut holding it in place....remove defective unit.5) Snake the black wire through where the on/off switch goes and connect it (they don't give you alot of play in the wiring so be careful. Attach red wire. Test it to make sure it works. Place the toggle back through the whole and carefully screw it back in. Replace the dial.6) Fold back into place and screw 3 sheet metal screws back in....7)Put grease traps and trim back together....
8)Brag to your buddies what a great handyman you are....and your wife too!
Posted on Oct 28, 2011
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
Viking hood Lights out
There is a short inside, you need to check wirings to locate the short.
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Vents in the Viking hood fall out on their own
Remove the filters.
The slot that the filters sit in at the rear edge, can be removed, it is basically hooked into place.
When you remove it you will see that the sides are different, reinstall it with the smaller edge hooked thus leaving the larger edge to hold the filters in place.
I hope this is clear.
Dec 12, 2008 | Viking VWH3048 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Oct 21, 2008 | Viking VWH3048 Kitchen Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
VWH 3648 Hood
most of them you have to take the filter off. under the filter, there are some screws. take them out and then it should drop the motor and you will see the electrical.
good luck
Jun 21, 2008 | Viking VWH3048 Kitchen Hood
do the heat lamps work?? or is it the 4 bright lights you are having the problem with??
Viking hood damper
Remove the blower and reach up into the duct through the back flow damper and put weather stripping on the 2 edges that are chattering, it will greatly reduce the noise
Dec 20, 2007 | Viking VWH3048 Kitchen Hood
Part PE050033 no longer exists. It's now two parts: PE050141 for the light and PE050156 for the fan. You must first remove all of the small switches then pull off the front panel to tighten the small nuts that hold the new units in place.
Dec 09, 2007 | Viking VWH3048 Kitchen Hood
Viking DTWL4848 Kitchen Hood Logo
264 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
