Question about Viking VWH3048 Kitchen Hood
Both lights went out not exactly at once but one shortly after the other. There was a smell like a new lightbulb burning. The smell is still there and the lights still don't work. All other contrrols work.
  • 10,865 Answers
If the bulbs have been working for several hours, they may have merely reached the end of their lives and burned out. I would begin by replacing each bulb with a new one. good luck
Posted on Feb 01, 2009
Installed new brake lights, now smelling burning plastic...?
I would say you have the incorrect bulbs in them.
Mar 11, 2017 | 1997 Toyota Camry
Burning smell
The light may have oil on it or be too close to the plastic housing. Bend the light socket to be as far from the plastic as possible. You may need a lower wattage bulb.
Jun 30, 2013 | Brother CS5055PRW Project Runway...
The light in my scanner ( microtek scan maker 9800xl ) first began to emit a burning scent and then it just went out. Where can I get a new light for it? How is it installed?
Hi Debmar22,
I don't think you'll be able to do it yourself. better take it to a nearby authorized service center and they'll do it for you. As for the burning smell, it looks like a short circuit withing the scanner (not necessarily a blown scanner light). One can't say at this point until it is opened up and checked thoroughly.
Best of luck.
Nov 05, 2010 | Microtek ScanMaker 9800XL Flatbed Scanner
Burning smell when lights are on
If the smell is gone 24 hours after the lights were turned off, turn on the fan & leave the lights off. Check for the burning order again. If you can smell it replace the fan. It will be the armature shorting out in the fans motor
Apr 14, 2010 | Hunter Fan Company 5/1/1 Programmable...
1996 saturn dashlights out
You may want to check the wiring under/inside the dash. The AC may have blown the scent of burning wires or other components from the dash. THere may be copper wires that have been exposed or have shorted one another. Then check on the fuse once all wires have been checked out.
Jun 08, 2009 | 1996 Saturn SL
2000 Subaru Impreza idling and accelerating poorly, burning smell
Try getting the fuel injectors cleaned. clean the mass air flow sensor .
------------------- also
is typically caused by insufficient lubrication to the camshaft synchronizer, which is the short drive assembly installed where earlier engines had a distributor. Once they begin to squeak, the bushing is shot, and the synchronizer must be rebuilt or replaced. They are available new, new aftermarket, and remanufactured. In extreme cases, looseness of the worn shaft will allow the rotating cam to destroy the cam sensor, which at a minimum will activate the "check engine" light and degrade engine performance, but more likely will result in failure of the engine to run. ---------------- also ---
What color is the smoke? Black - running rich. Bluish - buring oil. White - burning coolant.
Apr 03, 2009 | 2000 Subaru Impreza
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Burning smell
The sulphur smell is the result of the emmisions control system. I have an 06 Expedition with the exact same engine and emmisions system as yours. When the engine is cold, you don't smell that sulphur smell, but as soon as the engine gets to operating temperature, the exhaust gasses smell sulphury. Nothing wrong with your ride - they all do that. The dealership sometimes spray the underbody with some type of rubber to protect the vehicle against rust. This rubber stuff sometimes get sprayd on the exhaust as well and then you will smell "burning tires" after driving the vehicle. This will go away after a few thousend miles though.
May 15, 2008 | 2008 Ford Expedition El
Short in freezer?
IF THE WIRES SHORTED, AND THE DOOR WAS REPLACED,
WAS IT COMPLETE OR WAS THE DISPENSER ASSEMBLY TRANSFERRED TO THE NEW DOOR? IF THE ASSEMBLY ISN'T NEW, THE CONTROL BOARD IN THE ASSEMBLY MAY HAVE BEEN DAMAGED FROM THE WIRE SHORT.
Feb 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Viking VWH3048 Kitchen Hood Logo
265 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
