Removing the boot will require that the front panel, door switch and console be removed.
To remove the front panel first remove the three screws securing the toe
panel to the front of the washer and lift the toe panel up slightly
pulling it forward.
Next remove the two screws securing the top front panel to the washer. The front panel can now be removed.
try to unplug it fromt he back of your pc and open the side of your case and unplug the 2 or 3 onnectors going fromthe power supply and wait 10 or so minutes amnd plug them back in and see if that changes it if it powers back on that meant it has shut off either due to a short circuit and the system killed power to protect the system from damage or the system has overheated
Removing the front panel from a desktop computer to get access to the drive bays from the front is not too hard. Front panels are usually attached to the case by one of two methods. The plastic front panel can be held by spring loaded clips, you can see these clips if you look inside the case behind the front panel down each side of the front panel with two or three clips. The other way of securing the front panel is by screws, the screws are accessed from inside the case behind the front panel, usually by 3 screws down each side of the front panel.
if you have a factoy wiring harness c onnector, ford sometimes is supposed to put in the relay and the fuse for this. sometimes the **** at the dealer don't put these items in the fuse panel and the customer never finds out until they have their boat hooked up and ready to go!!!!
please rate if this helps.
Section 01-05: Trim, Interior
1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION
The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step.
Trim Panels, Door
CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
Disconnect battery ground cable (14301) .
Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item
Part Number
Description
Front Door Trim Panel Finish Panel
17B676
Outside Rear View Mirror Control
Door Lock Switch
55928-S55
Screw (5 Req'd)
5
14529
Window Regulator Control Switch
6
23942
Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
Remove front door trim panel retaining screw through front door trim panel finish panel opening.
Trim Panels, Door
Item
Part Number
Description
Front Door
383356-S100
Nut (2 Req'd Each Side)
56903-S58
Screw (2 Req'd Each Side)
Remove interior lamp lens cover.
Remove screw through interior lamp opening.
Slide front door trim panel upward to disengage hooks.
Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Disconnect window regulator jumper wire
Remove front door trim panel.
I don't know what the Nikec onnector is or does, but I can help you, if you think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
