Can't change temp
Thermostat won't go up past 75 degrees
    Problem Solver:
  • 17 Answers
Switch to cool and set the temp higher. Problem is it will not let you set the heat temp above the cool setting because would cause a conflict if tstat is set to auto mode.
Posted on Nov 14, 2008
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
My Honeywell thermostat won't set the heat above 75 degrees
ok fist thing is to press and hold the middle lower button and the arrow up at the same time and hold until the screen changes to a number. keep hitting next until you see 75 appear then arrow up to the temp you want and press done. That easy!
Oct 24, 2013 | Honeywell Programmable Thermostat Heater
I bought a Honeywell RTH8500 thermostat and I can't get the temperature to go down past 75 degrees
You will need the installation book that came with the thermostat. There is a way to enter into the programming of the thermostat from the home screen. From there, you will need to find what code is the temperature settings in the manual, they are usually all 3 digit numbers. Once you find the code for the setting your looking for which is the lowest temp for the thermostat, it will have a 75 to the right of it which you can set a lower number. Sorry I do not have the manual right now to just tell you exactly how, but hope this still helps!
May 28, 2012 | Honeywell Rth8500d 7-day Touchscreen...
My Honeywell Thermostat won't stay at the temp that I set it at!
You are likely running a schedule. When you go to tstat and change the temp it is a temporary setting that will expire in a given amount of time. 1, 2 3 hours etc. "HOLD" can sometimes bypass the schedule, "RUN" returns to the schedule. Not sure what model tstat you have but you have to exit your schedule.
Apr 18, 2017 | Honeywell Heating & Cooling
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Aug 20, 2009 | Carrier 38CKC042 Air Conditioner
I have a set-back number on my thermostat
the easiest way with a programmable t-stat which i assume it is, is to set the temp you want then press the hold button, otherwise if it isn't held at that temp at different times of the day the t-stat will resume its programming schedule.
Jun 29, 2009 | Heating & Cooling
Tried resetting the thermostat. Shows 70 degrees for a second. Then back to 78.5 degrees. When I use the arrow adjust to change settings the number does not change
Depends on your Tstat. The set point is different from room temp. My tsat show set point and room temp. But to answer you when you set at 72 and room temp is 75 . It will go back to room temp till you reach that temp. Rusty
Jun 07, 2009 | Heating & Cooling
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
