Question about GE Profile Harmony DPGT750EC Electric Dryer
Dpgt750ec1pl no heat or air
My dryer has no heat or air coming from it.We thought since there was no heat it was the heating unit,that didnt fix it,then we realized that there was no air.WE have checked the everything that the dryer says to check.I ran a lqc test and the dryer said blower 0rpm,heating --,inlet thd 162f ok,outlet thd 63 ok, moisture 4.92v ok,inputv 255 --,memory ok,comm data ok.did a voltage test on thermistor and it was 200.Not sure what else to test or what is wrong.so please any help would be helpful.If there is further testing that can be done let me know.Thanks Rebecca email becca@netzero.com
  • 8 more comments
  • becca43843 Nov 06, 2008
    Is there anyway to test the blower motor to make sure before I fork out more money.Thanks REbecca
    is there anyway to test the blower motor before I forkout more money?Thanks Rebecca
    yes we can get to the blower we have the dryer already torn apart with the whole front off.
    we have already done the troubleshooting on the dryer,and bought a new heat assembly.
  • becca43843 Nov 08, 2008
    there is no noise coming from it.we are going to have the blower motor tested before we buy a new one.Thanks
  • becca43843 Nov 11, 2008
    I had a electrician test the blower motor and there was nothing wrong with it.What else should be tested?
    The heating element is new.We bought it thinking that was the problem.
    All of that has been checked.had the blower motor tested,cleaned the vent.Ran lqc test,installed new heating element.The dryer had worked great earlier in the day,and then the last load didnt get hot or dry.And checked the vent and no air coming out of it.There was no noise or anything.
  • becca43843 Nov 20, 2008
    I did a dianostic on the dryer and it said the thermistor and blower and heating element.I have already bought thermistor and heating element didnt fix my problem.somone had told me how to test the blower can somone tell me again
  • becca43843 Dec 16, 2008
    Finally got dryer fixed.After buying new heating assembly,inlet thermistor,paying a tach and him telling me it was a inverter and he gave me model number and said if this didnt work contact GE and get main computer baord which is covered.Well his number for invertor board was main board which cost over 160 and was the computer covered thru Ge.So I fianlly bought the blower motor on ebay and guess what it fixed my problems after spending over 600.So it fixed and I now have a new heating assembly,inlet thermistor,2 main computer boards.I found out that the blower can show 14 ohms and still be bad.Hope this saves somone else from spending so much money.
  • 905 Answers
You should be testing the timer/control board to make sure there is nothing wrong there , check the components that control the power to it
Posted on Nov 11, 2008
  • jason Nov 11, 2008
    a sensor near the heating , check that
  • jason Nov 21, 2008
    to test the blower motor you must first know what the voltage is for the motor , don't just hook it up to a 120v outlet , because that motor may not be rated for that and you would blow it for sure! let me know what the rating is on the motor and I'll tell you the best way to test it.
    electech
    President:
  • GE Master
  • 2,651 Answers
Sorry for the silly questions but you note that theres no air coming form the machine, is hte motor runnin at all??? bescause if the motor runshte blower will spin. if hte motor not running at all , i would check for a bad thermal fuse, which would also account for a no heat issue
  • 685 Answers
You need a blower for ur dryer
  • GE Master
  • 19,396 Answers
The technician normally test the blower motor, by accessing to the part, and energizing the motor, there must be also a fuse or a circuit breaker and the motor wirings, that must be checked.
You can find schematics and parts here, just enter your model number.
Posted on Nov 08, 2008
    President:
  • 1,952 Answers
Have you taken the unit apart to see if the heating coils is broken? If not, you should do so because there are many reasons for no heat. Let me know how you determined the element bad.
The model number you have submitted to us is incomplete or not correct for your unit. In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate.
Posted on Nov 06, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 09, 2008
    (Click to enlarge)
    Grid is 1 inch square
    Item #
    1089101
    Price
    $134.75
    In Stock?
    Yes
    Motor asm - blower
    mohammed marika thambi Nov 11, 2008
    What is the water level in comparison to the heating element after it
    fills? Also, are you sure the spray arms are actually spinning,
    sometimes a pot handle or the way you load dishes keeps it from
    spinning. Sometimes the pump is not sending enough water up to the
    upper spray arms. Sometimes, the spray arm develops a hole on the
    underside
    remove teh spray arm and then the large cover...underneath this large
    cover is a screen filter. Check this to see if it is blocked with
    debris....Let us know what you find. How deep is the water in the
    machine after the fill cycle stops
    Genius:
  • 1,447 Answers
HI
) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3)) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
    Genius:
  • 2,920 Answers
Have you checked the heating elements? and the limit switches
  • 958 Answers
Yes you can test the blower motor if you can trace the schematics and find which are the power wires. im assuming your unit is 110 volts. either way. you can unhook those two wires and run a separate wire to them then plug it to a 110 volts outlet. just be careful on handling live wires since they are dangerous and fatal. do it if you are confident enough to handle live 110 volts.
if they are 220 volts ac. i would suggest that you let a knowledgeable person to do the test.
tnx 4 using fixya,
drcool
  • francis rivero Nov 11, 2008
    hi,
    have you checked if after you use it and you want to run it again if you are closing the door tight?
    if the door switch is open, it will not run, no air and no heat will happen. please check the door that it is shut off completely and push the start button. the motor should run and you will have heat.
    tnx again 4 using fixya,
    drcool
    Genius:
  • 2,035 Answers
The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Good luck..
    Brigadier General:
  • 6,966 Answers
Offhand, I suspect the blower. A remote possibility is the thermal fuse right on the back side of the blower housing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
    Genius:
  • 3,422 Answers
Please click on the below link go through the troubleshooting steps:
http://www.appliance411.com/faq/dryerheat.shtml
  • 1,879 Answers
"dryer said -> blower 0 RPM" the blower ain't turning. can you access the blower ?
    Genius:
  • 1,239 Answers
Hi
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
  • ABHISHEK.C
    ABHISHEK.C Nov 06, 2008
    An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
    Genius:
  • 1,550 Answers
You need to replace blower motor.
Take the screws off from behind the control area.
Lift off the control and you will find more screws that hold the top.
Take off the top and look for screws that hold on the front panel.
Take off the front panel.
Take out the drum but at the same time take off the belt and make sure you remember how it wraps around the pulleys.
You should be close enough to work your way into the blower motor area
Ge profile dryer does not heat at times
Sounds like one of two things.
1) you have a bad connection, specifically, a loose connection that is making contact once in a while.
2) one of the "overheat thermostat switches" is failing.
If you wish to fix it yourself, you will need to dismantle the machine and have a testing instrument to look for the problems.
Be advised, however, if you take it all apart and it happens to be on a "I will be working now, thank you very much" cycle, you may not find anything!
It really needs to be "not working" for the flaw to show up.
Be blessed.
Feb 22, 2013 | GE Profile Harmony DPGT750EC Electric...
I have a roper changed heating element. Still blowing cool air. Sister didnt tell me it only comes on in cooldown cycle. Wats could this be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Roper Dryers
My ge dryer model dpgt750ec1pl is running but no heat i was wondering if this style dryer is suppose to show some fault codes i thought it was the heat assembly but since itsnot showing any codes i thought...
heatman101./
Apr 25, 2011 | GE Profile Harmony DPGT750EC Electric...
My dryer is turning blowing everything but getting hot to dry the clothes. what parts should i order? We have kind of thought it might be the heater assembly?? Any help appreciated. Model# DPGT750EC1PL ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | GE Dryers
Runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
76 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
