Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire is freezing everything
I've already had this lousy fridge fixed once costing me 160.00 Dollars and the same thing is wrong with it again 6 months later and now my food is freezing inside the refrigerator. Is there a permanent fix for this ice box or a recall to fix what keeps going out on it? I have the same problem. My modle # frs26r4cb5 will the factory fix, 5303918283 fit my frig?
    Genius:
  • 1,550 Answers
Heater system is not working properly.
You need to replace heater for your unit to solve your problem permanently .
Posted on Nov 06, 2008
    Genius:
  • 1,239 Answers
Hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.This component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.
Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
    Sergeant:
  • 306 Answers
U need to make sure that the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out then the  heat from the light being on could cause such a problem. Refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8’s of a turn. If the compressor starts, replace the defrost timer. For further help, you’ll want to call a professional appliance repair technician.
You can use a condenser coil brush to clean the coils periodically. Because the coils exchange heat, any dust, lint, or dirt on them cuts down its ability to exchange heat. You can buy a brush or any needed refrigerator part online here:
http://www.apwagner.com/index.php?main_page=index&cPath=5.
  • Frigidaire Master
  • 19,396 Answers
Try first defrosting overnight and moving the fridge away from the wall to leave some airy space.
P
  • Ginko
    Ginko Nov 06, 2008
    There can be several reasons for the fridge freezing inside, and they are not all necessarily faults.
    If the thermostat is set to too high settings and there is ice inside the fridge, it will produce more ice. To fix this you defrost the fridge overnight and then lower down thermostat settings.
    If there is not enough airy space at the back of the fridge, the coils will start overheating, the condenser wont be able to do is job efficently anymore, put the compressor under stress, and the fridge start icing.
    IIf the thermostat is faulty the fridge will freeze inside. The thermostat is located behind one of the walls inside the fridge and can be tested with a multimeter.
Refrigerator freezing food
Fridge thermostat dials are often problematical due to the ones that are numbered 1 to 10, is 1 the warmest or the coldest as the number is lower? Some companies put 'warmer' and 'colder' which avoids confusion. My advice, put it in the middle '5', and leave overnight, check the temperature in the morning with a fridge thermometer. Then change the thermostat dial to 8, and check it the next morning with a thermometer. The next day put it on 1, and leave overnight, check the temperature in the morning. If the thermostat has gone, all three morning temperatures will be the same.
You mention 'or as your website suggests', you know we are not Frigidaire or anything to do with the retailer? We are Fixya, people just like you, helping others. I am a caterer, and just happen to know about fridges. I get them repaired professionally, but always ask for a full explanation of what went wrong. We recently had a sandwich storage fridge that was freezing food, and it was the thermostat that needed replacing.
The things you did, cleaning the coils, will actually make the fridge run colder. The Defrost Thermostat is unlikely to be the problem, as when they don't work, the evaporator, the part that is where the chilled air comes from turns into a block of ice. When that happens, air can't pass through it and the fridge warms considerably.
Due to the damage this freezing is causing with your water and filter, I would suggest you call a service engineer and get it fixed professionally as you will be swapping out parts that are fine. Correct diagnosis is the key, and they will also check the gas pressure at the same time. Consumers can't work with refrigerant gas, it is *******.
Mar 14, 2017 | Frigidaire Refrigerators
I don't know what happened to my refrigerator but it is starting to freeze everything. I couldn't change filter because it was stuck, frozen in place. So i had to turn the fridge off so it could thaw out...
1 setting on a fridge is as cold as it can get so it will be close to freezing
should be set on 4 or 5
next if it still is freezing then the thermostat is failed and you will need to replace it
May 09, 2017 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
My freezer is not freezing anymore it is only 2 years old and the fridge is not as cold as it should be? do you have problems with this alot and how can we fix it without spending.. 500 dollars like sears...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 12, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
My Frigidaire Refrigerator FRT18TPHw1 freezes everything in both Freezer and Frig. However, some things I put in the veg bins does not freeze. It is 10 years old and wonder if the repair is more than...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Frigidaire Refrigerators
My frigidaire side by side freezer freezes up and the filter in the refrigerator leaks water. It makes ice fine but will not freeze ice cream. theres a big clump of ice in the back which is under a cover...
the leaking water is the problem. it needs to be fixed, but till then defrost again, use a fan it speeds the process, SHUT OF WTER to ice maker. restart fridge it will work normally. now find parts needed to fix the ice maker water feed.
the leaking water overwhelms the defroster. and causes a coil freeze up, this impedes cooling and air circulation over the evaporator coils
Jun 15, 2017 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
FRE196AS frigidaire fridge/freezer - fridge freezes everything!
Hello Nicola,
I suggest you contact Frigidaire in the UK, and explain the problem to them. I have included their website for you to do so. You can even call them. I checked with Frigidaire in the US and Customer Service tells me your fridge should not be failing at this point. Contact Customer Service and tell them how disappointed you are in the product; explain the issue; and insist they offer assistance to repair it. Frigidaire Customer Service here does not want to lose any customers, and that includes you. Be nice, but firm with them. I hope this helps you in some way. Let me know if I can further assist. Just trying to to help. :)
http://www.frigidaire.co.uk/contact.asp
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Aug 25, 2008 | Refrigerators
yea the proper fix for the machine is a control assy part number is 5303918283 this is the complete kit.
sounds like that they just replaced one of the parts in the kit
this is the factory proper fix
Nov 30, 2007 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
127 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
