Question about NEC Electra Elite 32D-1 Corded Phone
Speakerphone I was changing the time on the phone and must've pushed a wrong button bc now I can only hear other people on speakerphone but they cannot hear me at all. Any suggestions?
  • 149 Answers
Yes turn your mic light on. Feature 1 usually.
Posted on Nov 13, 2008
Change language to English
You can change settings on your speakerphone. To do
this, turn off your speakerphone, then press and hold the call button and move the power switch to the "e" position
until you hear "welcome to setup".
Follow the voice prompts to change settings for:
Language
Enable/disable voice prompts
Enable/disable Name/Number Caller ID feature
Size of favorite contact list (10 or 25)
Mar 10, 2014 | Motorola Mobility T325 Bluetooth Speaker...
How to get the speaker phone
Hi i've inserted a link to the manual below:
Turning the speaker phone on or off during a call On the screen, to toggle between turning the speakerphone on or off. The speaker phone icon appears in the status bar when the speakerphone is on. To avoid damage to your hearing, do not hold your phone against your ear when the speakerphone is turned on PAGE 48
MANUAL: http://member.america.htc.com/download/Web_materials/Manual/HTC_Aria_ATT/100810_Aria_AT&T_English_UM.pdf
Jun 27, 2011 | HTC Aria Cell Phone
Mitel 5224 Speakerphone not working
it is likely the phone is in headset mode. If you've got a headset button programmed, then it should be lit.... if so, press it and it should work for you.
If you don't, you might be able to use the blue superkey to either turn off headset mode or set a button.
Press the Blue superkey, Press an unused button in the two rows of buttons. Press the "Change Key" softkey (under the display). Press No until you see headset key... press Yes.
Press the superkey again to get out of the programming.
Now that you've got the key programmed for headset, press it, if it's lit, press it again. Test your speakerphone.
If this doesn't work, I believe you would have a defective phone and should report it to your system admin or telephone system vendor for repair/replace.
Sincerely,
Mark
May 31, 2011 | Mitel 5224 IP Phone
I have a Darth Vador 1983 speakerphone but it needs an adapter and the phone does not specify what kind. Any help would be appreciated. Thanks.
I have the same 1983 Darth Vader phone but mine does not require a power adapter. If you plug in the phone line and push the on/off button you should hear a dial-tone. Mine does have a spot on the back of base to plug in headphones or a microphone, I'm not sure which.
Jan 21, 2011 | Vintage 1983 Darth Vader Speakerphone...
Can't hear my outgoing calls
While you're in the call, use the volume buttons on the right hand side of the Tour to turn up the volume.
If you still can't hear, you might want to try using the speakerphone -- it's louder. The speakerphone button is the same as the dollar sign ($) button, just press it during a call to activate the speakerphone.
If the volume button makes your outgoing call sound better, but then the next time you make a call the volume drops again, go into the phone's sound settings (Home folder > Options folder > Phone Options > General Options) and under Default Call Volume, change it to a higher number, or to Previous.
Jun 14, 2010 | RIM BlackBerry? Tour 9630 Smartphone
When I get calls, I cant hear anything out of my phone unless it is on speakerphone, but the person on the other end can hear me perfectly. This has happened in three different Venus' that I have had...
did you change your earpiece setting on the my settings menu, it's under Sound settings. you can change it to low to high. And when you answer the phone, you traditionally answer it the portrait way?
Mar 06, 2009 | Verizon Communications Samsung Alias Cell...
My black berry pearl will only communicate through the speakerphone feature, not through the handset. Callers have stated that they could hear me on the handset setting, but it was obvious to them that I...
i used to work help desk for a major company. I've seen this happen many times, unfortunately your probably going to need to use your insurance to get a replacement phone this is a hardware problem inside the BB. take it to the store
Dec 26, 2008 | RIM BlackBerry Pearl 8100
Sony spp-s2730 speakerphone on base unit
Saw this once with a bad speaker and another time the reset process shut something off....
It's been about 6 years... sorry...
AL
Jul 17, 2008 | Sony SPP-S2730 Cordless Phone
AT&T 926 Corded phone
check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Feb 13, 2008 | AT&T 962 Corded Phone (A21076)
NEC Electra Elite 32D-1 Corded Phone Logo
138 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
