Question about Porter Cable 100 7/8 HP Router
Demaged Powercord How can I remove the top of the router to install a new cord? thank you
  • gcarcerano Nov 07, 2008
    How do you seperate the housing to install a new power cord.
  • tom May 11, 2010
    what model is the router, looks like a porter cable in pic should be a number.
  • 22 Answers
Web site,ace tool repair.com has a diagram. this should be very helpful. free
tom
Posted on Dec 13, 2008
How to connect powercord to recoil
Hi Ken:
Here's a youtube clip.
https://www.youtube.com/watch?v=iOI1UQDb8Ns
The principle is the same for most pull start motors.
- Take it apart (remove the starter assembly)
- Pull the cord out as far as it will go.
- Use a nail or screwdriver to stop the spool from rewinding
- Remove the cord
- Install a new cord the same way that the old one was attached
- Remove the nail (or screwdriver
- Re-attach the starter assembly
Ta Da!
Jan 08, 2016 | Garden
Powercord replacement
hi kim you need to get three new conectors and at least 13amp three core lead just wire up exactly as it is now at top just under the lid they are all pretty much same check you dont have any fluff around heater good idear with top off give it hoover out
Apr 15, 2013 | Hotpoint Dryers
Belking wireless router can't see my comcast cable modem
then login to router setup page with 192.168.2.1 type this one in the address bar of ur browser
then u will see router setup utility
then click on the restore factory settings on the left hand side under UTILITIES
it will ask u for password leave it blank and click on submit
then click on restore factory default
once it is completed then on the rite top corner u can find the internet status --- it has to be connected or else
u can unplug the modem and routers power cord and wait for 1 min
the plug the powercord of the modem first wait for few seconds till the light are stable on the modem then plug the powercord of the router
then ur internet light should be solid on the router
Dec 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I replace the Powercord on a Fantom XT64K Vacuum. The powercord shorted where is comes out of teh housing. I need to open up the unit & replace but need a service manual of instructions. Thanks...
I have done this several times, it's some what simple just take the unit apart and use the old diogram to replace the new one. Or take a digital photo of it opened so you have your own scematic. You should be able to purchess the cord at your local hardware store "be sure you get the same insulated cord" the numbers will be located all down the old cord. Also very important. If you have never done this before I recomend you have someone with this type of knowledge. For safty reasons. good luck and hope you save some $$$$$
Nov 14, 2009 | Vacuums
Kodak 5300 shows "color ink cartridge needs replacing",even with new cartridge,and new printhead..Ink level display shows color cartridge empty,and its brand new..
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Sep 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can't get power to my laptop.don't know if it's the laptop, or the powercord
Look for a friend around and trouble shoot swapping the power cords. But I believe it must be your power cord that should be replaced.
Do the trouble shooting before replacing.
Rate this, please.
Apr 23, 2009 | Acer TravelMate 4010 Notebook
I lost my powercord & adapter/transformer for my HP OfficeJet G55
Hello. You can look for the right power cord for your country here.
Thanks and please take a moment to give this solution a thumbs up and it solved your problem. Thanks.
Apr 05, 2009 | HP Computers & Internet
My iron needs a new cord
purchase it from==
http://www.powercord-manufacturers.com/
thank you for using FixYa
Nov 14, 2008 | Black & Decker Irons
How do I take my Miele S251i apart to be able to chenge the powercord?
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Sep 13, 2008 | Miele S251i Plus Bagged Canister Vacuum
Replace Powercord
It has a cord relief to hold the cord in near the bottom, you will have to pull that out, the cord goes in there and comes out by the motor where the the wires connect. So you will have to pull the motor cover off to get to where they hook up to.
Apr 15, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Porter Cable 100 7/8 HP Router Logo
155 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
