Question about Philips 32PF9966 32 in. HD-Ready LCD Television
Philips 32' lcd hdtv
When i plugged my computer into my tv using the hdmi input and i turn my computer on it goes through the loading screen then shows windows there. then after windows loads up it does a muli colored horizontal line then goes to black. i have a radeon 9500 video card with 128mb memory on the computer. I have gotten it to work with my other computer that has an nvidia card. any ideas?
Are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Posted on Aug 27, 2008
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Feb 26, 2013 | Element Electronics FLX-3211B 32 in. LCD...
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
How do I connect my asus laptop to my sansui hdtv hdmi? what cords do I need and do i need to do something special with my computer?
No,try websites like Ebay.com or Amazon.com to buy a HDMI cable.Plug the HDMI cable in ur computer USB hub and the other side of the HDMI cable to the tv HDMI hub.Go into tv menu goto the tv find the wright input of the HDMI cable is in ur tv input there it is ur LCD Tv as a computer monitor.
Nov 12, 2010 | Sansui HDLCD3210 32 in. LCD TV
''Please change your computer screen's resolution''
i just bought a philips tv and i have the same problem, have you found a solution?
May 03, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Oct 15, 2007 | Philips Computers & Internet
Philips 32PF9966 32 in. HD-Ready LCD Television Logo
253 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
