Question about HP Color LaserJet 2600n Printer
Gray background where printo on glossy paper 130g/m2
When print on glossy paper, printer print gray relief background and shadow print from page before. Only on glossy paper. On A4 plain paper all is OK. Toners is full and first in new printer.
  • diboj Nov 06, 2008
    Thank you for answer, but I am trying print blank page, but all page is marrbled gray background, with or without text or graphics, only on glossy paper ...
    If you have another solutions, thank you in advance ....
    Scholar:
  • 87 Answers
Be careful running "Glossy" paper through your laser printer. Make sure the paper package says that the paper is "Laser" paper. If your not careful the glossy part of the paper will melt on to your fuser leading to a major repair!
Inkworks
866-381-0541
Posted on Nov 07, 2008
  • 36 Answers
Hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Posted on Nov 06, 2008
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
Printer leaves look of burn marks as granular shadow over page
If the paper really is being burnt then there is a fault with the fuser roller temperature control. This would also make a smell. If this gray sheen is made of toner then this may be the laser unit not putting out enough power. The optics could be dirty. One thing to try before attempting repair- Reduce the print density to minimum in the printer advanced settings. This increases the Laser power. Good luck
Sep 22, 2007 | Lexmark C524 Laser Printer
Pages printing with a gray background
could be waste toner in printer inside the printer it may need a clean.
Apr 27, 2015 | Ricoh Aficio CL7100 Printer
I have one problem with hp laserjet P4014n printing all paper black. the background is black all but word are showing can someone help me in this
If your background is "Black" it's going to print it all black, change your background color to "Gray" and your machine will then print a gray background instead of black. Also note that when you print a black background your toner life expectancy will be no where your expected yield ratio is. Average yield is 5% for X (X meaning size of cartridge) amount of printed pages. If your printing a black background your utilizing 100% yield coverage. Not sure if this is the answer your looking for. However basic black and white printing with a black background will print the page completely black.
Mar 01, 2011 | Office Equipment & Supplies
Gray background only on odd number pages
your cartridge is defective.. just replaced a new one.
May 17, 2009 | HP LaserJet 1020 Printer
Brother 1440 laser printer. Started printing with
may some dust in corona ware or drum clean the drum.
Apr 06, 2009 | Brother HL 1440 Laser Printer
Shadowing/graying with printing
Hi fa1103:
Gray background
1. Do not use media that has already been run through the printer.
2. Try using a different type of media.
3. Print a few more pages to see if the problem corrects itself.
4. Turn over the stack of media in the tray. Also, try rotating the stack 180°.
5. Open the Configure Device menu at the printer control panel. On the Print Quality
submenu, increase the TONER DENSITY setting. See the user guide.
6. Make sure that the environmental specifications for the printer are being met.
try these steps to see if they work for you.
pdouglasss
Dec 23, 2008 | HP LaserJet 2420dn Printer
PSC1510 & Vista problem
The problem cannot BE solved. It's yet ANOTHER Vista screw-up.
Original Problem:
"No matter what I try - every page from Jarte prints out with an UNWANTED gray
background.
This does not always happen when I print from the web, make copies or print from
Microsoft Word. I ran diagnostics on my printer HP PSC1510 and it's fine.
Test pages print ok, too.
Please help - I had Jarte on my last laptop (Windows XP), it worked very well
and I liked it much better than MS Word."
I emailed Jarte Tech support and got the following answer:
"The problem you encountered is a bug in Windows Vista. You will see the same problem when using WordPad on Windows Vista. As you have noticed, not all programs are affected by the bug. The problem is occurring because you are using a Windows color scheme that uses a gray background color for text windows. Unfortunately, the only work around is to specify white as the background color to use for text windows. Hopefully, Microsoft will correct the problem in a future Windows Vista service pack."
Bob Flora
Carolina Road Software
Jul 14, 2008 | HP PSC 1510 All-In-One InkJet Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Gray background on 2/3 of the page from left
change the drum unit
if the problem dos not solved clean the scan unit
May 15, 2008 | HP LaserJet 4 plus Printer
HP Color LaserJet 2600n Printer Logo
234 people viewed this question
Seeker5211
Seeker5211
