Question about Cambridge Soundworks 740I CD Player
CD Player does not load CD
The CD player won't load the disk. I have a model 740. Thanks
  • Anonymous Dec 20, 2007
    I have the same problem: not able to load CD.
  • 3 Answers
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Posted on Mar 16, 2009
SOURCE:
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
1998 7 Series: MY 1998 BMW 740 IL HAS NO SOUND FROM THE C.D. PLAY...
CD Changer needs to be replaced... You can buy one online from Ebay. Make sure you have the correct model...
May 16, 2010 | 1998 BMW 7 Series
2003 silverado CD player
HI. you will need to replace the loading dock motor. once this replacement is done, you will have no problem loading and unloading your media. This repair will need to be initiated by Bose unfortunately. you will need to send it to Bose.
Jun 05, 2009 | Bose 32023 CD Player
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Nakamichi CD player ejects discs
I think either your disk player, or your CD is dirty.
You should probalyly try getting a Q-tip slightly dampened in rubbing alcohol .
and clean the inside of your player.
Or you should try a different disk
Dec 31, 2008 | Audio Players & Recorders
How do I operate the multi CD player on a 2004 Honda Accord LX?
there should be a load button some where on the head unit
what for it to indicate that it is OK to insert another **** then press load again
to change disk there should be a disk button
to eject the cd just choose what disk to eject eg cd 4 then press eject
Dec 27, 2008 | 2004 Honda Accord
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
Cambridge Soundworks 740I CD Player Logo
998 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
