Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washing machine
My washing machine this week has been making a very loud noise when in just about every aspect of the wash. My husband opened it up and looked under the plastic seal and noticed plastic. The plastic is from around the drum and has wallowed out. The machine will run and is not leaking My washer is making a clicking sound in spin cycle in rinse and was cycle. I can see that the plastic tub has split and shifted about 1/2 inch away from the front of the washer. This is the third repair on this washer this year. paying some 100 dollars to come out and another 200 to repair is starting to be a bit much. The drain pump was just repaired in May now this. Please Help. My husband is deployed and I would really like to give my three little girls a christmas gift other than a new washing machine.
    Genius:
  • 1,239 Answers
Hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
Posted on Nov 06, 2008
  • Whirlpool Master
  • 19,396 Answers
You need to replace the plastic gasket arounbd the drum.
You find replacements here.
  • Ginko
    Ginko Nov 06, 2008
    An alternative solution is ringing Whirpool customer support number listed on the owner manual, and either ordering the replacement part, or asking a warranty extension if available.
    A warranty extension is usually less expensive than one single repair, and will cover with guaranty for one year your appliance.
    See Whirlpool Customer Support
  • Ginko
    Ginko Nov 06, 2008
    If you decide to buy a warranty extension you can purchase a Whirlpool Service Plan or if you
    have questions about the service plan, call them toll-free at
    1-800-615-3572, Monday - Friday, 8 AM - 8 PM, and Saturday 9 AM - 5 PM, Eastern
    Time.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Samsung front loader washing machine making noise
IF IT IS VERY LOUD SOUNDS LIKE IT NEEDS BEARINGS REPLACED
Jun 17, 2012 | Samsung Washing Machines
My front loader wont pump out the water when spining and when the machine is washing it makes a terrible loud screeching noise.
Mine does the exact same thing, only now I can only wash underwear in it as anything else is too heavy for machine to turn while washing.... My socks have dissappeared wonder if thats whats stopping it from turning or maybe thats just my messy kids making them dissappear!lol I've all but given up on it and think I'll dump it for top loader...
Feb 16, 2010 | Samsung WF337AA Front Load Washer
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
May 16, 2009 | Washing Machines
you see plastic shavings??? thats part of the front tub assy, not a very fun part to change call a professionnal for that one. in the meantime id pop off the lower acess panel and make sure all 4 of the suspension rods are in place and not causing the tub to lay foward and rub
Oct 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Plug off the wall; open up behind. Possible some spring hs come off or a shock absorber is faulty. Can be easily fixed by you. You might have to take the top off.
Jan 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
