Question about Maytag Performa PAV2200
Performa Washing Machine Not Working
My washing machine just stopped, no sound no nothing. It will not drain, I can't even get a sound out of it. I know the outlet is working because the Dryer is on the same outlet and it works. Not sure if there is an emergency shut off that was activated because there was too much in the washer or what???
  • garrett2plus Nov 30, 2008
    mine was empty and just won't start now. Last load wasn't real large. Checked breaker all is ok so must be some type of switch?
  • 4 Answers
CHECK YOUR OFF BALANCE SWITCH ,IF YOU SAY IT DIE BEC. TO MUCH IN IT ,IT COUL BE THAT OR FOLLOW YOUR WIRE YOU MIGHT HAVE BURN SOMETHING.SWITCH YOUR DRYER PLUG TO YOUR WASHER ANYWAY,CHECK THE LINE CORD IF THE TIPS ARE MAKING CONTACT.
Posted on Nov 11, 2008
Pressure switch?
sounds like you are having a syphoning issue. caused by having the drain hose too far down the home standpipe. very common problem. test..fill the machine, high water level. when it stops filling turn off. advance into spin/drain for just a moment and shut off. listen to hear water still going down the drain.
repair.. raise the drain hose nearer the top of the stand pipe. also do not tape/seal the hose into standpipe. it has to breath. good luck. kihm washing machine drain hose installation Google Search
Jun 13, 2017 | Maytag Washing Machines
I have a Matag Performa washing machine when it gets to the spin cycle it won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Washing Machines
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
Why my Maytag model performa, washing machine fill
Check drain hose not too low ...Syphon Effect....Good luck
Sep 29, 2009 | Maytag Performa PAV2200
My Washing Machine won't drain, the motor sounds but no spinning happens. Maytag Performa Model # PAV3240AWW
you have blocked filter or pump has an object in it if machine is about 2 to 3 years old pump may need replacing
Oct 19, 2008 | Maytag Washing Machines
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
My son has been given a HOOVER PERFORMA 1200 AC120 (used) he put his washing in it for first time it never drained or spun and now his clothes are stuck in machine full of water! the button you press to...
the washing machine must be empty for the door to open.
either open the trap at the bottom of your machine..prepare for flood!! or drop the grey drain hose to the floor and machine should empty.
glasgow domestics.
Feb 29, 2008 | Washing Machines
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Washing Machines Logo
104 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
