Question about EliteGroup GeForce 6100SM-M Motherboard
No display or POST
I put all parts together in case , when pc switched on there is no display and no POST tried to boot up without drives connected no difference
  • fishpie5 Nov 06, 2008
    When the power switch is pressed on computer powers up i.e. led glow and fans spin but display stays blank
    Problem Solver:
  • 6 Answers
WAS THE POWER SUPPLY WORKING? IS THE 4PIN BLACK AND YELLOW CONNECTOR FROM POWER SUPPLY IN PLACE? DID YOU TRY BIOS CLEAR? IF IT IS NOT A NEW BOARD - CHECK FOR BLOWN CAPS AROUND CPU (UPRIGHT CYLINDER TYPE THINGIES. RESEAT RAM. CHECK IF MAYBE ONE OF 24 PIN ATX CONNECTOR DIDN'T PUSH OUT OF SLEEVE.
Posted on Nov 06, 2008
  • CHRISTO PRETORIUS Nov 07, 2008
    IS IT A NEW MB? DID YOU RESET THE BIOS? CONNECT THE PC SPEAKER, IF NO BEEPS IS HEARD IT IS EITHER MB OR POWER SUPPLY. TRY ANOTHER POWER SUPPLY AND MAKE SURE THAT THE MB CAN HANDLE THE PROCESSOR
Boot failure, beeps and no display
Hi.
Do this solution first in the motherboard only processor installed need no memory.then power on your PC.if your motherboard no continues beeping.that need replacement of parts specially capacitor
leakage,became big or burn parts.
See beeping code.
Beep Code:
Description of Problem:
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
Jun 17, 2011 | Dell Motherboard For Precision 470...
After a power supply failed in my computer, I replaced the PSU and case witha 500W (higher) and new case. I have an M2N E SLI mobo, the same CPU I originally had, and the same memory in the same slots....
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Nov 25, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Jun 07, 2009 | Intel DG31PR Motherboard
No video display
take it easy. any thing in its time.
first take out all you have entered in pc case.
second dissasemble any part and reassemble it again out of case sure. ( only cpu , ram and vga card). try it inoutside the case is booting your Mb with ram, cpu and vga that you have entered or not?
if yes put the Mb in his place but do not conect another peripherials (like hdd cd rom etc). prove again is Mb booting with ram , cpu and vga or not?
if yes connect another peripherials and continue with system operating installation.
if yor Mb isn't booting from begining then check whats wrong ram or vga or cpu?
(for this you need another component like it).
if it is booting outside and not booting inside case put a thin plastic film under MB in contact with case, because you have a shrt circuit elsethere and proceed after that with the rest.
Apr 06, 2009 | Computers & Internet
MSI K8N NEO2 Platinum NOT Posting + No beep + No display
try to test the CPU on another machine ...
or at least remove it and reinsert it.
But if u say that u reseted the BIOS an it still not doing the post, it just could be that the motherboard is out !
It can also be the PSU as u say, but i doubd it ! Try to remove all hard drives, cdroms, etc... to limit the power usage... and see if it passes the post.
U can also try to remove the motherboard from the computer case and put it on an insolating surface and than try to boot (sometimes shorts appeare betwen the motherbord- case - psu)
Jan 08, 2009 | MSI K8N NEO2-Platinum (MS7025) Motherboard
EPoX EP-9NPA7I displays 'F' and '5' post codes
I would start by clearing the CMOS with the reset jumper pin on your mainboard. Then remove all the PCI cards excluding the video card; disconnect the hard drive as well. Boot the computer without the RAM and see if you still get the "F post code." If not download a copy of Ubuntu Linux and burn it to a CD.
Ubuntu 8.10 Live CD
Reinstall the RAM modules and boot to Ubuntu from the CD and run "System Memory Scan" from the Ubuntu Boot Menu. I'm guessing your RAM over-heated and is permantly damaged.
Only the manufacturer knows what the error codes for your board represent; it'd email them from this support link...
EPoX Support Contact
Nov 27, 2008 | EPoX EP-9NPA7I (0819366003415) Motherboard
Motherboard problem
Hi Conor, every SATA drive is a master drive. With that in mind you're SATA must have windows installed on it. Please disconnect the data cable & power cable's from the IDE drives.
(Do not reconnect either IDE untill you have finished).
Install windows on the SATA drive. Install all the needed drivers, than update windows. When finished Check the pin setting on the IDE drives. Set one as the "master with a slave" & the other as the slave. Than you can add both into the system. If you had windows on one of the IDE's just delete the root files on that drive so it does not conflict with the new windows on the SATA drive. Go in the bios make sure you have the SATA drive as the boot drive & not either of the IDE drives. If the system still shuts down after all this, try replacing the data cable for the IDE drives (Both should be on the same data cable). Swap the power connector from the CD-ROM drive to the IDE.
Next, if you're system still shuts down after adding either of the IDE drives, than swap the ports. Connect the CD-ROM to the primary IDE port on the board & the IDE hard drive to the IDE slave port. (This is for testing only). Double check all power connections from the power supply to the motherboard. Leave the case opened. Look at the board when booted. Watch for the the case LED's lighting up & flashing cr-rom's LED flashes, look at the CPU fan. Make sure all fan's are running & listen for the drives running.
Let me know if anything changed or not. Post any thing odd or if any thing did or didn't work & I'll go from there. Everything is a test & error soulation. One change at a time.
Mike
Jun 27, 2008 | Gigabyte Motherboard, GeForce 7100, Core 2...
No power up
Check the cmos reset jumper and check the case switch then.. I would look on the jumper positions for the case and short the PWR SW to see if the case switch is messed up. Then make sure to check all the peripherals.. remove them and re-install... make sure the memory is set in properly. Try to boot without any drives plugged in to see if any drives might be bad.
May 02, 2008 | ASUS P5N-E SLI Motherboard
Can not get any boot at all
Hi, First of all, your hard drive is what this computer needs to boot up. Try to see if you can POST, that is, only plug in power supply to motherboard with cpu and memory in there. Don't put any hard drive or other device into motherboard as yet. see if it reaches past post. If it does, then plug in hard drive and see if the problem occurs again. If it does, then the problem is the hard drive. But for now try reaching past post with only the bare necessary components for startup. Then let me know what happens.
May 02, 2007 | ASUS P4S800-MX Motherboard
EliteGroup GeForce 6100SM-M Motherboard Logo
94 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
