Question about Paradigm PDR 12 Speaker
Hum coming out of Front left/right speakers but not center
I  have an onkyo 606 amp. when i am watching a movie/tv there is a hum coming out of the speakers and i have no idea how i can stop that.  It is worse in other sound modes. How can i fix that?  Also I just got the paradigm pdr 12 and plugged it in the amp turned on and there was a high pitch screamming  noise that would not stop.
There is a chance that your wiring is producing this problem. Manufacturers don't always make equipment that is compatible with each other. The biggest problem's are "ground loops". Radio Shack has a non-electrical device that separates the common ground from all equipment. You basically connect it between your amp out's and in's - cables included. It is possible that other manufactures also make and sell this device too. It's main "Google" name would most likely be - "Ground Loop Isolators". If you are using the actually speaker outputs into your subwoofer amp input(s), check your polarity wiring again. Good luck with your system - it sounds like it'll rock when it's all setup correctly.
Posted on Mar 26, 2009
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
My center speaker is humming after i turn the tv on.
If you center speaker is humming, you when you turn on your TV, you may have the audio signal over amplified and the hum may be coming from your TV itself. Try moving the speaker further away from the TV or the amp further from the TV and see if it solves the problem.
May 24, 2011 | Coby DVD765 Theater System
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
Is there an incompatibility between Onkyo 606 and KEF Wireless?
This is cycle hum place offending units away from each other or, isolate the power supplies and, re- check electrical circuit grounds
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Sorry this is not a solution.
I am having virtually the same problem and I wanted to find out if you managed to fix the issue?
It seems to be my LCD causing the static noise (even when it is powered down). The static noise goes away when I physically unplug the TV or disconnect the HDMI cable to the amp.
Mark
Mar 23, 2009 | Onkyo TX-SR606 Receiver
Speakers work only on DVD
You might have connected your TV/Stereo Receiver up to the wrong audio outputs of the DVD player. Make sure you are coming out of the FRONT left/right audio outputs and not the CENTER?REAR left/right audio outputs.
Mar 13, 2009 | Panasonic SB-TP55 System
Hum from speakers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Dec 11, 2007 | Onkyo TX-SR604 Receiver
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Paradigm PDR 12 Speaker Logo
897 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
