Question about Dacor Preference SGM466SS Gas Cooktop
Oven Striker Basically my lighters don't work. I turn the gas on on any of the burners (except one, perhaps), but it won't light. Yes, I have tried making sure the knob is turned to "light", but unless I use a match or lighter the gas just keeps flowing with no fire. How can I fix the lighters?
  • 175 Answers
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Posted on Oct 13, 2006
SOURCE:
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
How do you fix the striker on a Sears Kenmore Pro gas cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 23, 2010 | Kenmore Cooktops
How do you light gas manually when power is out?
Turn your burner on to high, then use a lighter with the long spout on it to light the flame by moving the lighted flame to towrds the burner slowly.
Make sure to use the type of lighter that allows you to stay back so you do not get burnt.
If the burner does not light do not let it on for more than half a minute.
Heatman101
Jan 21, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Oven Clicking Noise
Sounds like you've got the igniter button stuck IN. If so it will probably carry on clicking until the battery runs down.
The battery might be behind the bottom drawer. If you take the battery out and the clicking stops then the striker button is probably glued up with something. Just clean it.
Oct 06, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
All burners won't ignite when knob turn to LITE
how lite a eletric gas oven when power lite dont work
Jul 03, 2007 | Whirlpool GLT3014 Gas Cooktop
Dacor Preference SGM466SS Gas Cooktop Logo
706 people viewed this question
Top Dacor Cooktops Experts
Marvin
Marvin
ray gallant
ray gallant
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
