Question about Denon CDR-M30 CD Recorder
No Green Light
I have a 3-in-1 Denon System made up of amplifier UD-M30, CD Recorder CDR-M30 and Casette Deck DRR-M30. All 3 parts were working well until recently when the CDR-M30 went on the blink. The problem is that when I press the On/Standby button it doesn't change from Red to Green, which means it doesn't function at all. I would welcome suggestions.
  • maddenpj Nov 07, 2008
    I've done this a hundred times. Light stays red.
    Brigadier General:
  • 6,966 Answers
Initially, this appears to be a built-in protection preventing the CDR-M30 to turn ON. The unit will have to be opened up for a look & see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 07, 2008
    President:
  • 1,952 Answers
It is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
    Scholar:
  • 44 Answers
If you are still having the same problem with yourdenon UD-M30 I might be able to help. I have fixed a number of them inthe past and have the necessary maintenance manual and knowledge of acompany that can supply spare parts. Disassembly looks very complex,especially when the problem is with the carousel but once you have anunderstanding of the mechanism it's not that difficult. Care should betaken when manually removing and reloading the disc trays as damage canresult to the 'Teeth' alongside each. Spare trays are available. All myrepairs involved the removal of the carousel mechanism in order toalign the trays. I can copy the relevant sections of the manual dealingwith the re-alignment which is critical but again if followed exactlyyou should have no trouble.
Sign up with Denon and you can download you manual: Here's the link.
http://usa.denon.com/ArchivedMicroSystem...
Here's their 800 number you can call:
Denon Technical Support, Operational Support and Customer Service
Denonoffers in-house factory Technical Support through our New Jerseylocation. Product Operational Support and Customer Service is alsoavailable at this location. Our contact information is as follows:
Phone Hours of Operation: 9:00AM to 5:00PM ET, M-F
Voice:
(800) 497-8921
(201) 762-6665
Fax:
(201) 762-6695
    Master:
  • 763 Answers
Try to check your manual sir and see if it has a configuration of it otherwise plug off your device for a few minutes and plug it on again. see what happens.
CHARCOIS
How to set time on denon ud-m3
press 'display' for 4 sec, then change hr with left arror, min with right arrow. easy
Mar 26, 2012 | Denon CDR-M30 CD Recorder
Hi ive got a denon drr-m30 it keeps on poping the back out
The solution from AlecBrown133 nails it. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr m30 and it is significantly cheaper than the 10 pound option.
Mar 12, 2012 | Denon DRR-M30 Dual Cassette Deck
DENON UD-M30 CD Player is displaying the word PROTECT and will not function. Any ideas how to fix this problem? Many thanks.
HI:
Usually when a receiver goes into protect mode, there are several reasons, One is there is a bad speaker connected to the unit, this will cause the unit to to into protect mode, try disconnecting all speaker from the unit and turning it on if it does not go into protect then one of the speakers are bad. Another reason is the power output Amplifier IC is shorted inside the unit. Another reasons could be that speaker wires are touching each other and causing a short. Disconnect all unit connecting to the unit and try turning on, if it stays on and no protect then connect them including the speakers one at time until you determine which is causing the error. If it goes into protect with nothing but the unit on then the Output IC is bad and the unit needs servicing.
Mar 10, 2011 | Denon CDR-M30 CD Recorder
I'm after an operation manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=48a11d4dbcc37e3208cc1f9c047ae817&modelid=363861&q=Denon+CDR-M30
Feb 08, 2011 | Denon CDR-M30 CD Recorder
CD JUMPING
Try looking into the lens (power off) with a magnifying glass. If you see any damage you will need to replace the lazer/lens section as the lens will never be able to read the disc.
If it's clear it's more likely to be an electronic fault.
Aug 26, 2009 | Denon CDR-M30 CD Recorder
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
No Aux on a UD-M30
We had the same problem, found that if you plug your device into "line 2 in" on the back and select tape it worked for our ipod. We had to turn the volume right up on the ipod to hear it though
Nov 12, 2008 | Denon CDR-M30 CD Recorder
Disc reading
How confident are you at opening it up? And where are you? If it can get table of contents info it could be gummed up grease on the laser sled.
Jun 15, 2008 | Denon CDR-M30 CD Recorder
Denon ud-m30
Yes it maybe a laser,if the repair cost still reasonable,why not.
Dec 14, 2006 | Denon CDR-M30 CD Recorder
Denon CDR-M30 CD Recorder Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
