Question about Toys
250 trailboss polaris atv
I am going to take off my wifes oil pump because it is not working right. I need to know if i can just take it off and put a block off plate there without causing any problems? and also what ratio i should mix the gas at?
Yes you can. Have done the same thing on old Quads and skiis.
As far as ratio's depends on how you ride.Just trail rideing I do around 16/1 But thats just me .Do some research its all out there..
Posted on Feb 23, 2009
1987 Polaris 250 trailboss rear brake caliper dicontinued is there anything that will interchange
check an oem supplier like cheapcycleparts.com, they usually list cross-references to everything else the part fits.
Mar 19, 2016 | ATVs
How do you disassemble this? Needing to check to see if spring is broke! Its for a Polaris trailboss 250 1993 model
Here's a link for parts info
https://www.google.ca/#q=polaris+trail+boss+250+pull+start
Being the mechanical sort that I am I would start by removing it from the machine and then try to determine how to dis-mantle it.
Some of these were rivetted together so may require some creative technical abilities to re-build.
Checking with the nearest dealer is always a good option.
Dec 30, 2015 | ATVs
How do you remove the thermostat from a 93 Polaris trail boss 350L 4x4
DOWNLOAD POLARIS TRAIL BOSS REPAIR MANUAL
trailboss-manual.blogspot.com/
Nov 5, 2014 - 4x4 free printable 1989 polaris trail boss 350 2x4 parts 03 polaris 350trail ... engine diagram trail boss 350 4 stroke diagram how to test the thermostat ... apolaris trail boss 1994 350 shop manual for 1993 polaris 4x4 trail boss ... boss 350oil pump repair manual for polaris trail boss 1987 removing jets in ...
Sep 25, 2015 | ATVs
I put new piston and rings in my polaris 1990 trailboss it started for a min and died whats wrong
was it literly a minute that it ran or was it like 10-15 minutes with you reving it up a bit? It could be many different things from as simple as it ran out of the gas that was in the carb and the tank valve is shut off to things like your magneto coil is shorted, no spark. Have you checked for spark and fuel? Does the engine have compression? More details will help solve your problem.
Brian
Dec 09, 2014 | Polaris ATV
How to replace a drive belt on my 2001 polaris trailboss
go to youtube and look for polaris belt changing vids. its pretty easy and they're all similar.
Aug 08, 2012 | RTO 125cc Full Size Adult 4 Wheelers ATV...
1987 polaris trailboss piston
Sure - it is worth fixing when a new one is 2300
Mar 31, 2010 | RTO 200cc Full Size Four Wheeler ATV
2001 polaris trail boss. it kept running very rough, no power, and died frequently, hard to start. acted like it was flooded. i opened the oil fill to check the oil level and it was so full it came running...
This happened to me with my trailboss also last week.
Take the carb off and clean it completely/ Drain the oil/
Put carb back on / Refill with new oil
your good to go.
(I had to clean the carb 2 times before it didn't to it again.
I was told the choke was stuck open or something.
Hope this helps!
Mar 06, 2010 | Polaris ATV
Brake fluid for a '91 Polaris Trailboss ATV
you dont need to check it just make sure that when u change the fluid that you fill it up to the top.
Mar 19, 2009 | Polaris ATV
Instructions to tighten the chain on a 2003 Polaris Trailboss 330
I have the same problem and it's wearing on my frame we tightened it and all it did was stiffen the suspension
Toys Logo
998 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
