Question about Apex Digital AD-1110W DVD Player
I need to fix this!
I have this DVD player and the power light on it just keeps blinking... and the eject button doesn't work. I press the button and nothing happens, not even a sound. I don't know what to do to fix it, please help me!
  • 3130 Answers
SOURCE: apex dvd player 1165, dvd keeps on ejecting before loading
Sounds like a mechanical problem of sorts . Hard one to call without opening and looking. Before you tear it apart I would try calling Apex Digital At 866-427-3946, as they are very good with there customers. Good luck
Posted on Jun 10, 2006
0 characters
1 Points
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Jul 25, 2009 | NexxTech DP3222 DVD Player
I have a Daewoo DF-4100P DVD/VCR combo. I have inserted a DVD that is unplayable. the disk just keeps spinning then gives up ..but I an unable to eject the DVD. I have tried resetting the DVD player. Is...
Hello there. I know you said that you tried resetting the unit, but have you reset it then pressed the eject button rapidly as soon as you press the power button. This usually works for me.
Dec 03, 2008 | DVD & Blu-Ray Players
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | DVD & Blu-Ray Players
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
DVD tray won't open
Hi kjflynn06 let your DVD player stand for about 2 days then you plug it in back if that does not work call a tech could be a faulty power supply good luck.
Apr 25, 2007 | Cyberhome CH-DVD 300 DVD Player
XV-N322 - Lock will not unlock
My problem was fixed by...having the DVD powered off, holding down the stop button on the player and hitting the power button on the remote.
Good luck!!
Jan 22, 2006 | JVC XV-N320 DVD Player
Apex Digital AD-1110W DVD Player Logo
18 people viewed this question
Top Apex Digital DVD & Blu-Ray Players Experts
Jonathon summesfield
Jaime Hernandez
Are you an Apex Digital DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
