Question about Microwave Ovens
Microwave Fan Keeps running
I have an Amana RC17 microwave and after I use the unit the fan keeps running. I moved it to another kitchen and when I plugged it in the fan came on again for 2 minutes.
  • William Miller
    William Miller May 11, 2010
    Let me be sure I understand what's happening...
    When you open the door and then shut it, the display will read "READY" and the fan and light will come
    on.
    At the end of the cooking cycle, the fan and light will shut off.
    The fan will also come on if the magnetron overheats or the sensor circuit has a problem. If this happens, the display will read "HOT".
    If the fan relay shorts, the light will be on and stay on.
    Which of these scenarios describe your situation?
  • mcamposan224
    mcamposan224 Sep 26, 2012
    display shows 00:00 when not in used. stop button does not work, fan continues to run. Exterior gets hot.
  • Microwave Ovens Master
  • 9,086 Answers
Neither the owner's manual nor the quick start guide for this model addresses that specifically, but most commercial microwaves do work this way to ensure proper cooling.
The manual does state that when you open the door then close it, thelight and fan will stay on for an unspecified period of time.
If the word "HOT" appears in the display, the magnetron is overheatedand the fan will run until the temperature is brought down.
If the fan fan NEVER shuts off, then there may be a stuck relay or defective sensor.
Posted on Nov 08, 2008
I want d manual of Amana Commercial Microwave Oven Rc17 1700 watts
You can download the manual from the manufacturer's web site at
http://www.kitchenaid.ca/assets/pdfs/literature/SK926001.PDF
May 27, 2011 | Amana RC17 Microwave Oven
Rc17 commercial microwave, display shows door even when door is closed.what can i do to resolve
Possible that the door lock switch is stuck and so is not releasing even after the door has opened. Look inside after disconnection of power to the microwave at the place where the door locks. Tap into the lock to release the switch . If the switch is jammed or damaged it must be taken out and replaced.
Mar 31, 2011 | Amana RC17 Microwave Oven
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
Our Microwave keeps running and won't stop. It is
The fan you hear is probably the magnetron cooling fan and that, and the light, are probably both controlled by the electronics board that controls everything else. You might inquire online at Maytag or the Sears parts department to determine the cost of a replacement board but I suspect it will either not be available at all or cost 3/4 of a new microwave.
Jan 23, 2010 | Maytag MMV4205 Microwave Oven
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
Abnormal noise produce by Amana microwave RC17
Deart Customer
please undergo the following
Since 30 to 50 percent of the power into a microwave oven is dissipated as heat in the Magnetron, cooling is extremely important. Always inspect the cooling fan/motor for dust and dirt and lubricate if necessary. A couple of drops of electric motor oil or 3-in-One will go a long way. If there are any belts, inspect for deterioration and replace if necessary.
An oven that shuts off after a few minutes of operation could have a cooling problem, a defective overtemperature thermostat, a bad magnetron, or is being operated from very high AC line voltage increasing power to the oven. One interesting note: Since 30 to 50 percent of the power goes out the vents in the back as heat, a microwave oven is really only more efficient than conventional means such as a stovetop or gas or electric oven for heating small quantities of anything. With a normal oven or stovetop, wasted energy goes into heating the pot or oven, the air, and so on. However, this is relatively independent of the quantity of food and may be considered to be a fixed overhead. Therefore, there is a crossover point beyond which it is more efficient to use conventional heat than high tech microwaves
i think the information would help u if so rate me please,otherwise just give it as fixya,Thank u
Dec 17, 2008 | Amana RC17 Microwave Oven
There is a bulletin that shows how to reset this code on Amana commercial microwaves.
We have uploaded it to our site here to help you.
Oct 03, 2008 | Amana RC17 Microwave Oven
Fan starts intermittently Amana AMV5164BAB microwave oven
Sounds like a loose connection or a failing hood thermostat. That's right behind the control panel on the base plate. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com/
Mar 12, 2007 | Amana AMV5164 Microwave Oven
Microwave Ovens Logo
589 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
