Question about Microwave Ovens
Fan keeps running
My microwave's fan keeps running for 2 mins after I had finished cooking. Is this supposed to be this way? I plugged in the unit on the other side and the fan went off for 2 mins also.
  • Microwave Ovens Master
  • 8,968 Answers
Neither the owner's manual nor the quick start guide for this model addresses that specifically, but most commercial microwaves do work this way to ensure proper cooling.
The manual does state that when you open the door then close it, the light and fan will stay on for an unspecified period of time.
If the word "HOT" appears in the display, the magnetron is overheated and the fan will run until the temperature is brought down.
If the fan fan NEVER shuts off, then there may be a stuck relay or defective sensor.
Posted on Nov 08, 2008
The fan on the one day old Oster Microwave runs after finished cooking. All cardboard has been removed.
It is supposed to run on and will stop on its own as long as the door is closed. The purpose is to remove steam and condensation, plus smells from the cooking cavity and cool down the magnetron (the part that emits the microwaves).
Nov 23, 2016 | Oster Microwave Ovens
Have a ge profile spacemaker microwave model# PNM18715M155. The vent fan cmae on while cooking and it wwill not go off. I unplugged and waited 5 min. plugged it back in a the fan still came on.
most likely you have a bad thermal fuse/limit device located behind control panel... there is a small round approx. size of a quarter that has 2 wires attached to it. this device has most likely failed as it is a heat limit and for some reason either the unit got to hot and closed the limit to allow the fan to continue to run or the limit itself has failed... you will have to remove control panel to gain access.... www.sears.com then hit the parts direct link on top and enter your model number to find the part and price ... good luck to you...
Jan 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We have just purchased a Kenwood microwave/combination oven and are concerned there may be a problem. When the food has finished cooking and the microwave beeps it seems there is a fan or something still...
In most modern combination microwave ovens, if not all, there is a fan that comes on after use to cool the magnetron and cavity down. This is quite normal but if you still have doubts, contact Kenwood's web site and send them a question.
Hope this halps to put your mind at rest.
Nov 27, 2010 | Microwave Ovens
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
The microwave keeps shutting off
I would suspect the internal cooling fan is not running, or the vents are blocked.
This would cause the magnetron to overheat, then the magnetron's thermostat on the magnetron opens, interrupting all power until it cools down.
This is to protect the magnetron from being destroyed.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 03, 2010 | Magic Microwave Ovens
My maytag microwave mmv1153bab cooks for about 4 min on high and then shuts off compleatly lights and all then 10 min later comes back on with a :0 in the display window what do I do
Run it with the exhaust fan on high,if this helps, the unit is over heating and has a bad cooling fan,Magnetron or Magnetron thermostat.
Sep 16, 2009 | Microwave Ovens
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
363 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
