Question about Canon PIXMA MP210 Photo All-In-One Printer
Black in fades towards end of print
I recently changed my ink cartridges and they are still quite full. The colour one is fine, but when when I print using black it always starts printing well but towards the end of the print it fades like the ink is running out.
My printer is not recognising the fact that I have changed my cartridges - it still thinks that there are empty cartridges in there. Could this be anything to do with it?
I have tried resetting etc but nothing seems to work.
Many thanks.
SOURCE:
SOURCE: Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Posted on Mar 29, 2008
SOURCE: Refilled cartridge not recognised by printer (canon PIXMA MP210)
get a new printer???
Posted on Jun 28, 2008
SOURCE: Refilled my Dell Ink Cartridge
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Posted on Aug 23, 2008
Silverblade
  • 173 Answers
SOURCE: Black ink not printing and colour ink very faded
Check the ink status of the printer's cartridge.
Posted on Oct 14, 2008
SOURCE: PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Posted on Feb 21, 2009
I have bought new genuine Epson ink cartridges, installed them correctly and although the settings are recognizing that there are 4 full, genuine cartridges it is not printing any black ink. I have done a...
I know it sounds stupid but do you have the old black cartridge, if you do put it back and see if it is printing even if the quality is poor and faded. If it is then possibly there is a contact bad, try swittching the black cartridge for one of the other colour ones, but put a colour in to the black space but don't put the black into one of the colour spaces. If the colour one is working in the black space then it's basically a dud cartridge and bring it back to where ever you got it from. Hope it works for you - Pat
May 16, 2011 | Office Equipment & Supplies
I do not need to print color documents. Will it print if I only replace the black cartridge and not the color cartridge?
you must have both cartridges fitted for the printer to work. The colour cartridge can be empty if you don't want to print any colour, but it must still be in there. When the ink monitor prompts you to replace the colour cart, just lift it out and push back down. This will reset the ink counter.
This is ok to do in emergency, but not a good practice as you'll end up with colour printhead full of air. If you're doing this to save ink, just buy some generic colour cartridges, they're quite cheap.
hope this helps
LC
www.inkbank.com.au
Nov 12, 2010 | Epson Stylus Color 740 InkJet Printer
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
Color ink is not working
Dear Black Rose
It is strongly recommended to change your colour cartridge.
Or it can be possible that you did not use your colour cartridge for a long time.
The nozzle of colour cartridge are blocked, if you did not use your colour cartridge for a long time.
Purchase a new cartridge if you can or go for a local refiller to refill (if possible) your colour cartridge.
Thanks
May 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
May 19, 2006 | Epson Stylus C64 InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
43 people viewed this question
Clive
Clive
old marine
old marine
